Does anyone have pics of B16 auto cams?
Old 04-26-2008, 09:59 PM
Dang EG's Avatar
Default Does anyone have pics of B16 auto cams?
I had these cams in my motor when I bought my swap a while ago. I assumed that it were GSR cams, since my motor was a GSR but the rings and notches on the cams do not line up perfectly like the pictures I have looked at but I could be wrong.
They do not look like the 5 speed B16, B17 cams. Slightly similiar to the GSR but not exact. Close to the ITR cams but still not exact.
I have been told they are AUTO B16 cams but I have never seen them before,
and can not find any pics of them cams on this site, I have searched.
Help me out guys!
On with the pics
Cam site: http://www.ff-squad.com/tech/temp/VtecCams.htm
[b]UPDATE - Took measurements going from right to left lobes.
Intake cam
1) 3cm
2) 3.5cm
3) 3.6cm
4) 3.3cm
Exhaust cam
1) 3cm
2) 3.3cm
3) 3.52-4cm
4) 3.47-8cm
Modified by Dang EG at 1:25 AM 5/30/2008
Old 04-27-2008, 09:35 AM
Dang EG's Avatar
Default Re: Does anyone have pics of B16 auto cams? (Dang EG)
bump
Old 04-27-2008, 10:38 AM
Dang EG's Avatar
any one?
Old 04-27-2008, 06:51 PM
Dang EG's Avatar
somebody gots to know?!
Old 04-27-2008, 07:13 PM
Pabs626's Avatar
probly b17
Old 04-27-2008, 10:29 PM
Dang EG's Avatar
Default Re: (Pabs626)
I know for sure that it is not B17 cams.. There are two protruding rings and no engrave rings. Mine are one protruding and engraved rings. Thanks for the help...
Old 04-27-2008, 10:49 PM
unsungfate's Avatar
Default Re: (Dang EG)
they look like itr cams...
Old 04-28-2008, 06:37 AM
Dang EG's Avatar
Default Re: (unsungfate)
I have been trying to figure it out but the protruding ring downs not fit the picture of any of the cams. The ITR's the closest but does it matter or is there someone that can 100% tell me what they are. I want to be positive before I put these for sale.
Old 04-28-2008, 08:47 AM
biggdogg's Avatar
yep auto b16 camz. i have a set that came with my b16 swap i knew it cuz it had a flex plate on the crank.
Old 04-28-2008, 11:32 AM
Dang EG's Avatar
Default Re: (biggdogg)
Are you for sure? Do you have pics of them to verify as well?
Thanks ....
If anyone else has any say in this, please go ahead....
Old 04-28-2008, 03:40 PM
biggdogg's Avatar
see if i can get over there 2mara. im almost positive.
Old 04-29-2008, 07:15 PM
Dang EG's Avatar
uppity!
Old 04-29-2008, 08:29 PM
slowcivic2k's Avatar
There is a lot of information that is not entirely accurate out there. I looked at the pictures from ff-squad to ID the cams from a 2000 JDM ITR, and they do not match. It says they are US spec 98+ cams. So.... either it came from Canada and got US ITR cams on the line, or someone from Japan put in US cams before I got it. Either way, it would be good to note where the engine came from, if possible.
If you have access to a micrometer, you can measure the base circle and lobe height, and let us know what the difference is. I'm sure someone on here has mic'ed these cams already.
Old 05-05-2008, 11:28 PM
biggdogg's Avatar
my bad dude. they r 95-00 itr camz. just look real close to the link u posted. i zoomed in on em real good.
Old 05-30-2008, 12:25 AM
Dang EG's Avatar
Alright guys, took some measurements with a micro meter and now can someone identify what they are?
Old 05-30-2008, 12:47 AM
denraweb's Avatar
Default Re: Does anyone have pics of B16 auto cams? (biggdogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg &raquo;</TD></TR><TR><TD CLASS="quote">my bad dude. they r 95-00 itr camz. just look real close to the link u posted. i zoomed in on em real good.</TD></TR></TABLE>
I agree
Old 05-30-2008, 02:15 AM
Derrickdean85's Avatar
Default Re: Does anyone have pics of B16 auto cams? (denraweb)
they are b17 cams. Itr cams have those rings but they are not as big.If you measure the lobes on the secondary they will be around 36mm and the itrs would be at 37mm. here is a pic.itr onleft b17 on right
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
notice howmuch bigger the secondary on the itr is than the auto b16/b17 cam
[IMG][/IMG]
Modified by Derrickdean85 at 3:32 AM 5/30/2008
Old 05-30-2008, 07:02 AM
Dang EG's Avatar
Default Re: Does anyone have pics of B16 auto cams? (Derrickdean85)
Finally, that clears it up! thank you...
Old 05-30-2008, 07:08 AM
Dang EG's Avatar
Hold up, I see that you go the pics from FF squad but if you use the link that I got, the B17 cams do not have that ring on the first part and double on the second part...weirdo...
Old 05-30-2008, 07:30 AM
Dang EG's Avatar
your correct, they are b17...bump to that...
RustyE.G.
11
10-23-2013 04:29 AM
CarAudiophile
29
05-11-2005 11:32 PM
crexer
03-07-2005 08:46 PM
91b16civic
05-13-2003 04:26 AM
LsTurbo91
05-15-2002 12:57 AM
Quick Reply: Does anyone have pics of B16 auto cams?
