Do a swap or drive it till it dies?
Hey Guys,
I am new to this forum and I hope to establish some roots here and create a network of friends.
I just recently acquired a 96 Civic DX Hatch and it currently has 230k miles on it. Bushings will be replaced, as well as the steering rack. My question is: Should I go ahead and replace the motor or should I drive the D16 till it dies? The motor feel like it runs strong and doesn't give me any problems.
This will be my daily driver for the next 5 years (hopefully) so I am patient with my mods. However, I don't want to be driving it to school or work one day and it just craps out on me. It has the original transmission and motor so the previous owner did not abuse it. So I don't know if I should take a chance and see if it lasts till 300k or take the swap.
Re: Do a swap or drive it till it dies?
Just change the timing belt and water pump and give it a tune up and oil change and maintain it and it should last more than 300k
Drive it as is, keep it maintained. In the mean time get a goal/plan and save up for the motor you want in it and when you have everyting then swap it out.
No reason why it wont go to 300K + no problem. Keep it in good shape and maintain it. I currently have 265k on my Y8. If your worried about the health of your motor do a compression test and a leak down test.
Seagull Management
I would keep driving it while I put money aside for a swap personally. In terms of doing a swap, spend the money upfront and do it right the first time, it's cheaper in the long run.
Are you burning any oil with you your y8? I am close to you in mileage and burning quite a bit.
I was thinking the same thing. If it dies on me suddenly, I'd have to wait for the new motor to come in plus the installation time. However, I am very curious on how far this motor will go.
I have siblings who won't mind me bumming for rides if it does drop out.
On another note, do you guys know what else I should be replacing on an old car as this to keep it as a reliable DD? So far I have in mind: New struts, steering rack, bushings, and fixing the freaking AC.
I forgot to mention that I will also be replacing the Fuel Pump because it seems to have a hard time starting every now and then. It won't start after sitting for a while, but then starts up perfectly every time after that during that same day.
The previous owner already replaced the water pump, plugs and wires, fuel filter, timing belt at 180k, brake pads.
Believe it or not, I bought this thing for $400.
these are old cars now, i would recommend to replace all hoses and belts along with new water pump and timing belt. then start on all the bushings for the suspension.
My dad's accord has 280k on it and counting. Stock everything, as long as you take care of it, it will last a very very long time, especially if you do regular maintenance on it, (my dad doesn't and look how far he's made it).
You could change a few things here and there, but other than that, save up your money.
When you hit the 5 year mark, you'll have enough money saved to build just about anything.
if your motor still runs strong just maintain it. i have a 97 hatch too, and i just swap a b16 in it. it's nice but not all that. save money for a gsr, or ls vtec, more torque.
Seagull Management
Check the main relay first. OEM Honda fuel pumps hardly ever go bad.
gobblebox59
45
04-12-2004 06:56 PM
