Do Slotted/Drilled Rear Rotors Make Ebrake Better?
Re: Do Slotted/Drilled Rear Rotors Make Ebrake Better? (BLUE EH3)
No, on drilled/slotted rotors there is simplyless friction surface then a blank rotor. So your stopping distance will be less.
Re: Do Slotted/Drilled Rear Rotors Make Ebrake Better? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">No, on drilled/slotted rotors there is simplyless friction
surface then a blank rotor. So your stopping distance will be less.</TD></TR></TABLE>
less effective you mean.
Re: Do Slotted/Drilled Rear Rotors Make Ebrake Better? (Cory Matthews)
Rotors have little to no effect on the ebrake, and the only difference is in the thickness of the rotor, but it's not an issue as long as the pads and rotors are both within spec thickness.
Rebuild the calipers.
Re: Do Slotted/Drilled Rear Rotors Make Ebrake Better? (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">
#2 In any case I DONT CARE, the rear brakes dont do crap to begin with other than to provide an ebrake.....AKA, why it takes 100,000 miles before you need to replace rear stock pads.</TD></TR></TABLE>
Thats funny.
Thats funny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">the rear brakes dont do crap to begin with other than to provide an ebrake.....AKA, why it takes 100,000 miles before you need to replace rear stock pads.</TD></TR></TABLE>
Have you ever ridden in a car with no rear brakes? My friend put a new rear end in his AE86 and didn't have the rear disc brakes hooked up for a little while. That car sucked at braking. Rear brakes make a big difference.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">Just wondering if anyone with these has found that the crappy Ebrake worked better with slotted/drilled rotors.</TD></TR></TABLE>
No, absolutely not.
As a matter of fact, drum brakes make the best type of e-brake - hence the reason that several modern cars with 4-wheel discs utilize a separate drum setup just for the e-brake.
No, absolutely not.
Re: Do Slotted/Drilled Rear Rotors Make Ebrake Better? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
No, absolutely not.
As a matter of fact, drum brakes make the best type of e-brake - hence the reason that several modern cars with 4-wheel discs utilize a separate drum setup just for the e-brake.</TD></TR></TABLE>
true, my dad's camry had this setup. I was like wtf? when I saw it.
No, it won't make a difference imo.
No, absolutely not.
Azxster
14
10-11-2007 10:07 PM
ComCool
02-24-2005 07:34 AM
