do all P30 ecus monitor knock? (ie: jdm compact p30 ecu)
I have a jdm p30 ecu, its the square kind that is smaller than conventional honda ecus youve all seen. well i was reading on the hondata site, and in the column for "knock" there wasnt a Y, so im thinking if this is the same ecu that doesnt monitor knock. does anyone have any idea? i wanna throw this thing in my car so i can get it properly smogged... my knock sensor is damaged and i dont know if i am getting the one i just bought soon enough to get the car smogged... heres the hondata site:
http://www.hondata.com/ecus.html
im not sure if mine is the asia/euro, or in fact the "jdm" one. im hoping its the p30-g and not the p30-o, but i have a feeling its the p30-o. so if u can help, id appreciate it. thanks guys!
krazy
krazy
1 Post
Re: do all P30 ecus monitor knock? (krazy)
best way to tell is throw it in your car and see if it throws a knock sensor code!
as far as i know,it does have the KS circuit.i've done a couple JDM B16 swaps that included the small P30 ECU,and the motor had a knock sensor in it-can't imagine why they'd put one on there if it isn't needed.i added the KS wiring,assuming it was needed,so i can't positively confirm that it would or wouldn't throw a code without the KS hooked up.
chris
Modified by TeamNextGenChris at 7:12 PM 1/16/2004
chris
euro spec and australian ecus with the following numerations P30-GXX or P30-QXX
are the only ones without a knock sensor. JDM ecus (small case) and USDM P30 do look for knock sensor.
JDM ecus are usually P30-0XX or P30-JXX or P30-NXX while USDM P30-AXX and so on.
XX=variation numbering and does only distinguish the auto and 5spd nothing else.
my suggestion is to either have the ecu chipped with stock program that disables the knock (such as the euro program) or simply get another knock sensor (one from 96+ EX or Si works just fine)
Re: do all P30 ecus monitor knock? (eg6ajk)
Thanks so much for that piece of information. I think I know what I'll need to do. I talked to the guy I purchased the knock sensor from, and he said either today or tomorrow I'll get it. So thanks again H-T!
krazy
krazy
