Dizzy Help
Dizzy Help
ok, i just ordered a new dizzy for my b16. heres the question
I know how to put the dizzy on, but when i did my swap i marked the position that the dizzy should be at(etched lines on the top of it) for proper timing. when i get the new dizzy, how can i set the timing correctly w/o my cheater mark.
Re: Dizzy Help (shaggy420)
Note which cylinder the rotor is firing. Then place the new dizzy rotor firing the same cylinder. Put the distributor in and you should only be a few degrees off at best. (when you put it in try to make it line up like your old housing).
But the proper way would be to jump your service connector and use a timing light to set the ignition timing
i have a timing light but im not sureif it is engine specific. it was my grandpas and he had a couple domestics. i also just got an aftermarket ignition set (jacobs pro-street) so is that going to change anything?
timing lights are universal. Just put the pick up on number 1 cylinder with the arrow (if there is one) facing towards the driver side. Hook up the pos/neg terminals and set it to whatever spec it is (normally 16btdc)
crappyshifting
07-18-2013 09:00 PM
IloveNewt
05-24-2003 08:32 PM
