Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Honda Accord Brake Guides
- Honda Brake Modifications
Overview of popular modifications to customize your Honda.
DIY: BRAKE Upgrade - Integra Front Brakes with DX Knuckles!!
#26
Re: (BrakeExpert)
Can the calipers from a DA integra work? Aren't they the same size as the DC integras? I have a set laying around. If they won't work, I'll take them back to the junkyard and get the calipers from a DC teg or Prelude.
#28
Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">He's using Type-R calipers. Not the regular GSR/LS/RS/DA calipers that your thinking of. That's the only reason it works with the stock knuckle... </TD></TR></TABLE>
I know he's using the prelude/legend/ITR type calipers. I just want to know If the DA calipers would work. No biggie though, I'll either just take them back to the junkyard and get some lude calipers, or just stick with the stock setup and go with a better pad/brake fluid setup. Bigger brakes would bump you up in a higher class in autox anyway which I plan on doing.
#30
Re: (94eg!)
For you guys wanting to do this setup let me tell you it's great. I'm from Venezuela, I talked to BrakeExpert, found the calipers, bought from him the brackets and rotors (since I couldn't find them here in Venezuela), got them shipped overseas and mounted everything on. I had to grind a little bit the bracket for it to clear the 15'' Rotas I had back then, now I've got 14'' steelies and they clear just fine (but at the limit), but no problems, have been running like that for a long time...
Do not hesitate to try this setup, he's a good seller and your car will brake the hell out of you.
#31
Re: (Imprezor)
Hey good to hear from ya. So you finally got em on and clamping like champs. Thanks for your vouch, glad those brakes are working well for you. Yeah I remember you were like the first guy I made those brackets for. Now I'm running 12" NSX brakes on the front and may be swapping to AMG ones later.
The 10.3"/ ITR brakes were still awesome, I loved how they were soft to the touch on initial pedal feel like stock, but then started to get really agressive the more you press. Best brakes to clear 14s by far.
#32
Re: (BrakeExpert)
Yeah you showed me the pics the other day...
I'll be doing the rear disc conversion this month, or the next. I will tell you how I did on it.
#33
Re: DIY: BRAKE Upgrade - Integra Front Brakes with DX Knuckles!!
hmmmmmm i have set of ex knuckles for my 89... but i'll have to try this swap on my 88 when the brakes are all gone.
#35
need help i have rear SPOON rotors which are 4x114/4x100 i tried fitting the rotor on my rear caliper but my stock eg6 caliper wont wrk there to small im asking will the gsr rear caliper wrk or i have to get rear 4x114 rear calipers ?
DeeEx Rex
08-28-2013 06:34 AM
Redline96LX
01-29-2007 09:40 AM
Propulsion
06-12-2005 10:44 PM
