DIY 5lug conversion question.
Old 10-06-2004, 08:05 AM
Go Tigers!
Bense's Avatar
Default DIY 5lug conversion question.
I have been wondering this for a while. in the prelude vtec big brake conversion for our egs/eks it says that you can either buy the prelude rotors or the ITR rotors and drill them to 4x100 so i know that these rotors are the same size. Also you can either buy the prelude calipers, ITR calipers, or NSX calipers. My question is, If i was to buy the ITR or CRV hub which can bee seen below, would it be possible to place this in my GSR knuckles with the big brake conversion and have a po-mans 5lug conversion?
Modified by thebense at 12:26 PM 10/6/2004
Old 10-06-2004, 08:09 AM
pdiggitydogg's Avatar
...I dont know why I havent thought of that before
Good question
edit**
isnt the axle on those 36mm? or is that only itr
Old 10-06-2004, 08:24 AM
ej0513's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">...I dont know why I havent thought of that before
Good question
edit**
isnt the axle on those 36mm? or is that only itr</TD></TR></TABLE>
36mm is ONLY JDM ITR 5-lug.. everything else including our ITR is the same which i believe is 32mm..
Old 10-06-2004, 08:50 AM
TypeRVETECH's Avatar
Default Re: DIY 5lug conversion question. (thebense)
u can use the jdm civic 5 lug swap. thats allu need
Old 10-06-2004, 10:57 AM
jappwr's Avatar
Bump
Old 10-06-2004, 11:25 AM
Go Tigers!
Bense's Avatar
Default Re: DIY 5lug conversion question. (TypeRVETECH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRVETECH &raquo;</TD></TR><TR><TD CLASS="quote">u can use the jdm civic 5 lug swap. thats allu need</TD></TR></TABLE>
sorry, i don't feel like spending 900 dollars.
Old 10-06-2004, 04:47 PM
bump this
Im curious
Old 10-06-2004, 04:53 PM
gezer's Avatar
bump...... tru dat save the 9 bills and dump it on something else.
Old 10-06-2004, 05:06 PM
Mr HYDE's Avatar
Default Re: (gezer)
wow that is somethign i never thought of doing
Old 10-06-2004, 05:17 PM
xerox445's Avatar
there may be an offset issue though..i know with my gsr hub/prelude rotor/itr caliper, there is a 3mm offset issue from the rotor, and such. What determines that, the hub or the whole knuckle itself...worth a shot tho.
Old 10-06-2004, 05:19 PM
slambedcivic's Avatar
Default Re: (ej0513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 &raquo;</TD></TR><TR><TD CLASS="quote">
36mm is ONLY JDM ITR 5-lug.. everything else including our ITR is the same which i believe is 32mm..</TD></TR></TABLE>
the accord has 36mm axle nuts.
Old 10-06-2004, 06:44 PM
Go Tigers!
Bense's Avatar
Default Re: (slambedcivic)
how about getting the ITR hub and redrilling the 4lug rotor to 5lug? And before you guys flame, sorry that i don't have the funds to fork out 1g for the "real" conversion and another 500 for wheels
Old 10-06-2004, 06:50 PM
xerox445's Avatar
Default Re: (thebense)
why would you want to do that...i hate people that just want 5 lug for bling...
Old 10-06-2004, 06:51 PM
Go Tigers!
Bense's Avatar
Default Re: (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">why would you want to do that...i hate people that just want 5 lug for bling... </TD></TR></TABLE>
what if i want the gunmetal ITR wheels?
Old 10-06-2004, 06:55 PM
LOOKALIKe_eh2's Avatar
whats that gotta do with bling foo, just cause u want 5 lug dont mean u want bling, how about the option of diff wheels that u can get instead of the regular stuff..... just help the man out....... dang whats with people jumping all over the place cause the foo wants to do his own 5 lug, either u can help him out or dont bother to post it will help everything run smoothly with less problems
Old 10-06-2004, 07:05 PM
Calvinator's Avatar
damn, i wanna see if this can be done..
Old 10-06-2004, 07:18 PM
xerox445's Avatar
i thought you didn't have 9 bills to spend on an expensive 5 lug conversion, and another 5 for afford heavy ITR wheels? would it help if they were imported from japan?
upgrade your **** for performance, not for looks...that's my motto any who.
I mean, you want to get all technical and crap so here we go.
First of all, you don't use ITR rotors on a 94+ integra hub.
1. They are not hub-centric and will cause all sorts of problems and vibrations.
2. They are 5 lug, and much harder to drill to 4 lug, due to place of studs, and lack of material.
I believe you can get a ITR wheel bearing, and hub and have that pressed in. You actually don't even need a press, I've done it b4 a few times with my hubs with a axle hub puller and a slide hammer, rented from autozone, 20 bucks a piece. You can even keep them if you want. I know for 20 bucks, i definitely kept the axle puller.
Your idea of drilling a 4 x 100 rotor to 5 lug is novel, but it wont work.
1. The offset of the rotor is different then the ITR.
2. The thickness of the rotor is different then that of the ITR.
3. The lug pattern is different, and would be a pain in the *** to drill.
4. You would loose the 2 screws that hold the rotor on the hub. (Note i know most don't run them, but i expect this being a problem because of #5.
5. The 4x100 is hub centric, where as the ITR is lug centric. The Clearances on the 5 lug are a bit tighter to hold it in place on the hub exactly center. The screws keep them in place. I don't know this for a fact, but if you have a problem with lug centric on a hub centric, then it must be viceversa.
6. This is assuming your using a different caliper, if you don't it just wont fit, the rotor is larger in diameter.
So, yes its very apparent to me that your interested in 5 lug for a much different reason then i would be. That's why i made my 4X100 setup which includes:
GSR Knuckles
ARP Extended Lug Nuts
Honda OEM Open Ended lug nuts
96 Prelude Vtec Rotors Re-drilled to 4 x 100 and balanced
2001 ITR Re-man Calipers
Prestige 3mm, and 8mm Spacers
Stainless Brakelines
GSR Master Cyl and Booster
4040 Non-Abs Prop Valve
GL with the 5 lug in any event....
Old 10-06-2004, 10:25 PM
letmeseeyouskip's Avatar
i thought of doing that b4 and i know that the GSR and Type R has the same hub/knuckle so why wouldnt it work but if you can already get the 5-lug hub shouldnt you already have the whole 5 lug conversion layin there
Old 10-06-2004, 10:34 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">
the accord has 36mm axle nuts.</TD></TR></TABLE>
And 5th gen Preludes
Old 10-06-2004, 11:30 PM
civtegra_hybrid's Avatar
I would think that you could use CRV 5 lug conv. just press the the old one's out and press the crv ones n, and in the front you can use the crv cali. and the rear try the itr's or even the prelude one's, I know the crv hubs will fit in the front, (same axle's) I don't know if any one tryed this **** before
Old 10-06-2004, 11:54 PM
O3DigitalBath's Avatar
JDM ITR, accord, prelude, CL and I belive TL
Old 10-07-2004, 03:10 AM
Built B16A's Avatar
Location: hittin corners so hard you can taste my rims..
Default Re: (O3DigitalBath)
ok.. then to throw in another wrench in..
if you go out and buy ITR hubs, and rotors, will the clear the 92-95 EX/SI calipers?
Old 10-07-2004, 07:55 AM
xerox445's Avatar
Default Re: (Built B16A)
no, unless you got a a 94+ integra or ex/si sized rotor with 5 lug pattern
You wouldnt be getting any kind of brake upgrade tho with that
Old 10-07-2004, 10:14 AM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">no, unless you got a a 94+ integra or ex/si sized rotor with 5 lug pattern</TD></TR></TABLE>
theordicly, if you take a bone stock 95 Si.. and order USDM ITR hubs and rotors, they will clear the EG calipers?
i understand pad coverage would still be the same, but you would be 5 lug.
Old 10-07-2004, 12:58 PM
Go Tigers!
Bense's Avatar
okay, so the CRV hub will work in the front, because the CRV uses the same axles. That would leave us with the rear in question. I dunno if there are any CRVs that aren't AWD that have all disc brakes. my GSR brakes don't have ABS. And i'm not sure if there are any ITRs without ABS, so i don't know if i could use the ITR rear hubs. perhaps maybe the prelude vtec rear hubs? can ABS hubs go in non abs steering knuckles?
Quick Reply: DIY 5lug conversion question.
