distributor rotor: screw not sitting flush, taps surrounding pastic once every turn?
im changing out the rotor, and the screw is not sitting flush. how big of a deal is this? should i exhange for another one or sand it down so that it doesnt tap the plastic surrounding when it rotates; it taps it once every turn.
Re: distributor rotor: screw not sitting flush, taps surrounding pastic once every turn? (devils_civ
Is it the oem screw? or did you replace it? if its the screw thats suppose to be there back it out and try not to cross thread https://honda-tech.com/forums/images/smilies/emthup.gif
its the oem. I think the replacement rotor place for the screw is a little thick. is this a big deal? thanks for the input.
Re: (devils_civic)
I would return the rotor for another or run without that cover.
Re: (Luserkid)
yes it is a big deal cause when i was racing one night i brought my shit up 9k the same exact screw your talkin about came loose and it was so hot it fried the piss out of something cant remember the name and my car just died and wouldnt start had to get towed.
thank you all so very much for the input, i will return it to see whats up. maybe a wrong part?
