Distributor cap for SiRII ???
None of the 99-00 Si or the del Sol VTEC caps work... wtf??? Which cap do I need to get to fit my b16a SiRII motor???
Re: Distributor cap for SiRII ??? (Mario.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. »</TD></TR><TR><TD CLASS="quote">None of the 99-00 Si or the del Sol VTEC caps work... wtf??? Which cap do I need to get to fit my b16a SiRII motor??? </TD></TR></TABLE>
You may have a aftermarket distributor. Most internal coil Honda distributors use the same cap (some accords use a different cap)
Re: Distributor cap for SiRII ??? (Turbogixxer)
aftermarket distributor shouldn't make that much of a difference....should still utilize a stock cap....Im thinking that maybe the wrong distributor is on the bad boy, or maybe someone swapped the guts from one distributor sub-assembly to another.
Re: Distributor cap for SiRII ??? (civic_fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_fan »</TD></TR><TR><TD CLASS="quote">aftermarket distributor shouldn't make that much of a difference....should still utilize a stock cap.</TD></TR></TABLE>
No, Same distributor king do not run OEM cap (or fit for that matter) and use their own rotor too. Like I said, some aftermarket distributor uses different caps. If it is a rebuilt, it will most likely use a OEM cap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_fan »</TD></TR><TR><TD CLASS="quote">Im thinking that maybe the wrong distributor is on the bad boy, or maybe someone swapped the guts from one distributor sub-assembly to another.</TD></TR></TABLE>
If the car is running without codes for the distributor, mostly like it has the right distributor. Most internal coil Honda distributors use the same cap. OBD-0 is the exempt. But, if the car is running, I doubt it is the OBD-0 cap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">No, Same distributor king do not run OEM cap (or fit for that matter) and use their own rotor too. Like I said, some aftermarket distributor uses different caps. If it is a rebuilt, it will most likely use a OEM cap. </TD></TR></TABLE>
hmmm....the aftermarket distributors here in Canada must be different than US ones...all the aftermarket distributors Ive dealt with have used a stock cap and rotor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">If the car is running without codes for the distributor, mostly like it has the right distributor. Most internal coil Honda distributors use the same cap. OBD-0 is the exempt. But, if the car is running, I doubt it is the OBD-0 cap. </TD></TR></TABLE>
It doesnt have to be the stock distibutor to be running w/o ignition system codes...you can swap out internals from an OBD 1 distibutor sub assembly into an OBD2 sub-assembly and run without codes. When you do that, there is a possibility that it will use a different cap and rotor. And like you said yourself, most internal coil B-series distibutors do use the same cap (Part no. 30105-P54-006 [interchangable for 30105-PT2-xxx] here in Canada) but there are instances where the cap isn't the same.
Re: Distributor cap for SiRII ??? (HOOKUPS)
won't work...He said that he tried to use an Si and del sol VTEC cap already and to the best of my knowledge, they, as well as the 97 teg LS, all utilize the 30105-P54-006 cap.
He could try a ITR cap....worth a shot.
nope....Ive got an LS engine and it uses the P54 cap...same as a 99-00 SI
Part number is different when looking it up, but it supercedes internally at Honda to the P54 number.
Trust me. I know this for a fact.
be professional
If it's an OBD-1 B16A, the distro cap should be the same as '94-95 Integra GSR and '94-95 del Sol VTEC . . . not '96-97 del Sol VTEC or '99-00 Civic Si.
Re: (nstabl)
Thanks guys.
I did ask for a 1995 del Sol VTEC cap and it didn't work.
It can't be an aftermarket setup because right now it has a TEC Honda cap on it.
Re: (Mario.)
Does anyone know if the number inside of the cap signify's anything? It's like M1xxxx . If so, is there a way I can use this number to check what car it came off of?
Curlybandit
09-07-2017 07:09 AM
Knightrider
02-08-2002 09:56 PM
