distributer wont fit?
i have a d16z6 that i just put together. after i tried to put the dizzy back on & it wont go in. any suggestions?? the dizzy is from my old d16z6 head.
PHANTOM MENACE
Re: distributer wont fit?
The key way is offset so that the distributor will only line up with the camshaft one way. Look at the notches on the end of the camshaft and rotate the end of the dizzy the mates up to it as needed.
alright so i had to take out the rocker arms, re did it..now it fits. and now the head is on the block with timing belt on. i loosen all the valves to do valve adjustment, but #2 exhaust and #3 intake are stuck open..is the motor suppose to spin freely when i loosen all the valves?? because right now it feels like its stuck when i try to spin it
Take the spark plugs out. Just from reading it sounds like you don't know what you are doing. You need to consult a service manual before performing this task. There are also numerous videos on the internet for this procedure.
Here's one I found just Googling
http://www.denlorstools.com/home/dt1...honda_car.html
[QUOTE=EJ8_Man;47431817]Take the spark plugs out. Just from reading it sounds like you don't know what you are doing. You need to consult a service manual before performing this task. There are also numerous videos on the internet for this procedure.
X2
Look up ERICTHECARGUY on youtube.
Do you know how to do a timing belt? Im not trying to be a dick Im just asking.
X2
PHANTOM MENACE
How would the rocker arms prevent the distributor from fitting? Unless you removed them and just did a bad job reinstalling them I don't see how they would prevent the distributor from being bolted down.
For those valves, if the rocker arms are loosened then the only way they could be stuck open is if they are bent (or something very obvious in the springs would be there holding them open but that would have to be a ridiculously big piece of debris to do that). How are you determining that they are stuck open anyway?
headhunter
11-10-2005 11:34 AM
EGcivicBoy
10-21-2004 09:25 AM
