distributer problem
distributer problem
So i washed my motor down and even thought i bagged the distributer... it got water in it. I went to take it off and one of the little bolts that hold the cap on snapped. what..... do i do?
Re: distributer problem (biggjerryc)
If there's enough of the bolt remaining, try backing it out with a pair of needle nose pliars.
If that fails, drilling it out is your best bet. Preferably using a reverse drill bit to back it out when it catches and some steady hands, should be no biggie.
Same **** happened to me, had to swap dizzy casings because the drill messed it up .
Re: distributer problem (Syndacate)
well at this point... i dont even feel like going through the work unless a casing is expensive. that brings up the question... how much is a distributor casing?
LX4CYL
10
12-09-2005 06:06 PM
Erod
19
04-18-2004 01:06 PM
