Distributer cap and oil pan civic 2000
Old 05-24-2019, 06:23 PM
Default Distributer cap and oil pan civic 2000
The engine is swapped from D16y8 to D15z6. The car has more than 300k KMs on Odo.
I have recently changed oil after almost 2 years. I used 10w40. Oil level is not coming down but these pictures shows very bad picture. Is there any problem?
Also near the pcv valve the cover has oil.
Secondly how to clean these parts?
Hasan Khurshid is offline
Old 05-24-2019, 06:26 PM
Default Re: Distributer cap and oil pan civic 2000
Old 05-24-2019, 06:36 PM
Old 05-24-2019, 10:05 PM
Intelligently Stupid
TomCat39's Avatar
Are you saying the oil has not been changed for 2 years?
TomCat39 is offline
Old 05-24-2019, 10:24 PM
Yes but now changed last month. And it was not changed as car runs very less and most of the time parked but still there was no oil loss and safely it has done less than 10k kms in 2 years
Old 05-25-2019, 08:43 AM
tony_2018's Avatar
You need to repair the vacuum line from your valve cover to the intake arm. You need to clean up the oil residue to investigate if there is a leak.
tony_2018 is offline
Old 05-25-2019, 05:27 PM
Can I wipe it with a wet cloth?
Old 05-25-2019, 05:29 PM
what are the purpose of these 2 lines under throttle body and why it is not connected?
Old 05-25-2019, 05:32 PM
Should the flywheel be seen from underneath like in this photo or something is missing or broken? This is s40 transmission
Old 05-25-2019, 05:34 PM
What is part called and is it broken and what is the purpose?
Old 05-25-2019, 05:36 PM
what is that silver part down inside with a metal tube connected?
Old 05-25-2019, 07:18 PM
chrysler kid's Avatar
Youre missings the transmission dust shield.
chrysler kid is offline
Old 05-25-2019, 07:19 PM
Youre missing the fender liner splash guard. I do not see anything out of the ordinary other than that
Old 05-25-2019, 07:21 PM
The silver tube is the air conditioning drier. Its used to remove humidity and make sure freon inside the ac system remains pure
Old 05-25-2019, 07:26 PM
Please familiarize yourself with the engine bay and you will find many of the answers you seek by just reading through the service manual
https://www.clubcivic.com/forum/thre...anyone.176563/
You can clean the transmission and block by spraying engine degreaser like purple power or simple green onto the dirty surfaces and useing a brush to agitate the surface and then spray clean with a water hose. Rinse and repeat process until clean. Do not soak electrical connectors with water or cleaner, a little water and cleaner will not hurt them at all. Just keep the alternator dry
Old 05-25-2019, 07:33 PM
Thanks very much Chrysler
I have downloaded the manual and I am getting fimilarize with my engine bay. But here in Pakistan, mechanics really don't care about doing the job properly and neatly.
Can you tell me if transmission cover is not there can this damage anything?
Secondly the gear oil may be overfilled because it was filled from the top by removing a sensor and now it has leaked. The mechanic said that it is easy to fill from top. Does it has any bad effect on transmission?
Old 05-25-2019, 07:40 PM
Yes fill from the top is easiest, however there is a full hole on the side of the trans behind the axle that will leak out excess oil when the transmission is full. If you remove the full plug any extra fluid that is not needed will come out. I believe this is a 21mm bolt behind the axle on the passengers side
The cover is a good idea to use as it will keep debris such as gravel out of the transmission.
Old 05-25-2019, 07:44 PM
chrysler kid
Old 05-25-2019, 07:56 PM
Old 05-25-2019, 08:05 PM
The 2 lines are to heat the throttle body with coolant to create even temperature being let into the motor. The coolant lines go into the throttle body then out to the idle air control valve according to the diagram. Techbically it is not vital the throttle body is connected to coolant unless you live in a cold climate area
Old 05-26-2019, 12:10 AM
I think the resonator box is also broken.
And one more thing it can now suck water from here if I take into a deep puddle?
Old 05-26-2019, 06:40 AM
tony_2018's Avatar
So don't drive in deep puddles?
  • Ask a Question
Question Title:
Description:
