dist. install HELP
dist. install HELP
seems straightforward but some info please?
do I need to set it at TDC before removing the old one? if so, will I need an imapct gun to turn the crank? if no TDC is needed is it as simple as it seems?
Re: dist. install HELP!!!!! (XenoPhobe)
HELP A NOOB OUT!!!!
Apparently I need a TD # off the distributor to order an aftermarket one. Problem is there is no such number ANYWHERE on there. The only number is this: D4T94-05.
96 HX D16Y5. ANYONE?!?!?!?!?!?!? My distributor is about to die from oil in it. I need one ASAP and I ain't payin $400 for a reman honda pos.
