disabling the o2 sensor heater?
i was wondering how to disable the o2 heater sensor. i know there was a post a while back but can some1 do anouther write up with pics
Re: disabling the o2 sensor heater? (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">i was wondering how to disable the o2 heater sensor. i know there was a post a while back but can some1 do anouther write up with pics </TD></TR></TABLE>
why would you want to do that? The only way I know of is uberdata
Re: disabling the o2 sensor heater? (specv5150)
If you disable the o2 sensor heater your o2 sensor will not be able to obtain an accurate reading as soon as it should with the heater on it. o2 sensors usually have to be up to about 400-600 degrees F in order to obtain a fully accurate reading. I wouldn't advise you remove the heater wires or disable it in any way because you're not going to go into "closed loop" as fast which will decrease fuel economy.
Re: disabling the o2 sensor heater? (r3dh4tch)
i just wanted to know if there was a way.well can someone do a write up on how to rewire the 4 wire o2 to the ecu and fuel injectors .......bump
Re: (mike93eh)
are u talking about the two black wires? because i thought that one was the positive and the other was the negitive,if im wrong please correct me.are the any pics ilistraiting(cant spell ) doing this?
Re: (mike93eh)
well the problem is that i replaced the o2 and im still throwing the 41 cel .i really need to get a diagram of rewiring the o2 heater wires.if u have pics of some1 doing this u will be my hero for life!
Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">well the problem is that i replaced the o2 and im still throwing the 41 cel .i really need to get a diagram of rewiring the o2 heater wires.if u have pics of some1 doing this u will be my hero for life! </TD></TR></TABLE>
so.. that pic doesnt explain enough?
Guest
Posts: n/a
Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">i just tryed doing the resistor thing and all it did was heat up the resistor and burn my hand .anyways ya what does that mean? ......bump</TD></TR></TABLE>
means you didnt do it right
Re: (mike93eh)
ok i went out and got a 10w 10o resister and i connected the two black wires with it between them.i dont think im doing it wrong but im starting to think that theres a break in the heater wires.im guessing its the injector one(yellow and black) if theres any one that can give me directions on how to rewire the yellow wire,help. because im clueless and i dont have the cash to send it to the shop
......bump
......bump
