Which direction does coolant flow?
Old 06-11-2019, 07:47 AM
  #26
Default Re: Which direction does coolant flow? (Spoon Hybrid)
You're right!
RMOT is offline
Old 06-11-2019, 08:33 AM
  #27
chrysler kid's Avatar
The pump doesn't flow any coolant, it just builds pressure. The thermal heat moves the coolant through the system. The hot coolant moves up in the motor and once cooled goes down into the radiator. The thermostat keeps the hot coolant in the engine until it goes put to the radiator
chrysler kid is offline
Old 06-11-2019, 09:36 AM
  #28
NukeNinja's Avatar
Another way to look at it is what direction would the water flow if there was no water pump? The water in the radiator cools down and becomes more dense and flows downward due to buoyancy. It's called natural convection. You would not want your pump (forced convection) to work against natural convection. It would require a larger, more powerful pump to overcome the natural forces. Also, if you shut the engine off, the coolant flow will coast down, but continue to flow due to natural convection. If you pumped in the reverse direction, when you shut off the engine, you would have a flow reversal, with no flow for a moment.
NukeNinja is offline
banks358
Northeast (Sales)
10-03-2016 11:20 AM
hondallday
11-02-2009 07:31 PM
Bc3
08-24-2009 04:50 PM
pkolaboy
04-09-2008 09:19 PM
KarbinFourteen
03-03-2004 09:29 AM
Quick Reply: Which direction does coolant flow?
  • Ask a Question
Question Title:
Description:
