Direct Fit Manifold Convert - wtf is that?
This is a continuation of a previous thread, but now i have different questions. Girlfriend dropped car off, and the quote for 2 motor mounts and a direct fit monifold convertor is 1,500.
The issue is that the header is cracked (see image). She needs to replace this, which i've found for $80 on ebay etc... So, being that as far as I know, this is the header, and is all that's busted. So whats up with the Direct Fit Manifold Convertor? Is this #4 on the other image, can we get by without it if we buy the performance headers?
What kind of cheap options do we have?
Re: Direct Fit Manifold Convert - wtf is that?
If you get an aftermarket exhaust manifold, that will be replaced. The stock cats are definitely expensive; $400-500 last time I checked (my '94 CX manifold is cracked and hasn't been replaced because I don't want to spend that kind of $ for a new cat). But then it depends on what state you live in and what kind of emissions testing they do. You might be able to get away without getting a cat at all, and just hooking up the new manifold to your stock exhaust. Or you may have to get a "regular" cat, and fit it in between the new manifold and the exhaust (probably just means you'd have to have the exhaust shortened and some flanges welded on).
I would suggest going with an 80 dollar cat and taking it to a mufler shop to mount every thing up because that particular exhaust system has no space for a cat so they would have to ad a cat flange and shorten the pipe for you to fit an after market cat on then you can just bolt that up to the header
Buy ya a universal cat online and get a cheap OBX header off ebay for your car and you'll be $$$ ahead and get much better performance over OE. Have an exhaust shop weld it up, should set you back more than $250 for everything!
Resident Gearhead
Is that first pic your engine? Looks like a B series, block stamp looks like it says B16A5?
If so you don't need an exhaust manifold with integrated catalytic convereter. Just get one for a B16 or whatever engine you've go there.
B16A2:
B16A2:
broncoman74
02-18-2009 10:46 AM
skumdum
12
09-30-2004 03:19 PM
talagangpinoy
05-30-2004 09:10 AM
