difficulty of mani swap
im swapping intake manifolds on my cx.goinmg to the ex..either the z6 or y8 ..im wondering from personel expirience and opinion, how hard is this swap? is it a couple hours garage swap? and will my injectors and rail swap also? thanx guys
Re: difficulty of mani swap (yaleforizzle)
bump
i know b series manifold are a bitch to do while they are in the car.. with a single it may be easier its only like 8 12mm bolts holding it on but you might have to get a new gasket if yours rips and you should be able to just switch everything over no problem ... but then again im not a single cam kinda guy http://images.honda-tech.com/set1//smile/emcrook.gif
i've never done a sohc i/m swap, but a dohc i/m swap is really easy, just a bit time consuming
Re: (dantastic)
Hey read up in here....https://honda-tech.com/zerothread?id=335078
and also try searching in case you haven't. I'm positive this has been dealt with. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: difficulty of mani swap (widebodyjaeg16b)
hmm, yea i hear ya...thanx..someone told me that id have to like crimp the fuel lines or something? anything i have to do involving the lines?
