difficulties rebuilding a d series tranny
I bought a d series manual tranny for 50 bucks today (good price )
however the guy mentioned it had about 80k miles..
im thinking about making this a project to learn and try to rebuild it myself. or get it done (no real concern for time soo this will be fun)
i want to make sure this tranny is strong when i put it in for my auto to manual conversion.
Re: difficulties rebuilding a d series tranny (igo4bmx)
You shouldn't have any problems with a 80k miles tranny as long as it wasn't driven too hard. As far as a rebuild you could replace all the bearings and syncros but that will cost alot and if the tranny is in good shape there is no need to replace anything.
Re: difficulties rebuilding a d series tranny (nsxmatt)
understood, but its always hard to get good opinions from people sellign their own items...
he could have said there were no problems... but who knows...
maybe i will email him now and get his honest opinion
if it's all in good condition, go ahead and put it right on. good luck on your auto-to-manual.
Re: difficulties rebuilding a d series tranny (TrickHonda77)
yeah its been a cheap project
tranny - 50
shift linkage - free
ecu- 50
short shifter and **** and es shifter bushings -70
clutch master cylnder -60
buying soon
hydaulic lines-60
pedals -60
slave sylinder-60
tranny - 50
ecu- 50
buying soon
hydaulic lines-60
pedals -60
slave sylinder-60
Risky Business
Re: (2faz2paz)
check over all the synchro's (the gold thingy's with teeth on them) and make sure they look okay...also when you take the gears out spin all of the bearings and make sure they are all smooth and dont click...if they click, they need to be replaced. At the absolute LEAST...you should replace the input shaft bearing...which I did on my car and it fixed several problems...
Synchros (the gold thingys)-
A bad syncrho-
https://honda-tech.com/zerothread?id=596873 - my writeup y0
A bad syncrho-
Re: (BauleyCivic)
very good write up, but the pictures are missing...
can you upload them to my site
http://www.jameschong.com/updown ???
thanks
thanks
Solbros Owns Me
Re: (Ricey McRicerton)
the actual synchros usually don't go bad, it's the sleeves that slide over the brass synchro ring. These wear more often than the brass gear.....just to let you know
Risky Business
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">the actual synchros usually don't go bad, it's the sleeves that slide over the brass synchro ring. These wear more often than the brass gear.....just to let you know</TD></TR></TABLE>
interesting...good to know
ONELIFEMOTORSPORTS
10-22-2006 04:50 PM
