difference between rod knock and valve knock?
My car got hydrolocked and now I am just trying to figure out if its a rod knocking or a valve. Is there a way to tell the difference
Re: difference between rod knock and valve knock? (dank24)
I was going to ask the same thing so I would like to know to. they seem to be the same symptons but I guess there are differences as I was told I need a valve adjustment and not 1 person said it was my rods...
well i was thinking it was my valves. But since i hydrolocked my car I am hoping its not a rod. So i was trying to find out whats the difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dank24 »</TD></TR><TR><TD CLASS="quote">My car got hydrolocked and now I am just trying to figure out if its a rod knocking or a valve. Is there a way to tell the difference</TD></TR></TABLE>
if it's hydrolocked, it's probably a rod.
compression test, chances are if u bent a valve then ur compression will be low, i'v heard a spun rod it was loud, if it is a semi-mild knocking i would say it was the valves
Re: difference between rod knock and valve knock? (2wheelhunter)
here are two vids of mine. i was told it was was my valves so if yours sounds like mine then mabe its just your valves.
http://smg.photobucket.com/alb...Anch2
http://smg.photobucket.com/alb...Anch1
Re: (dank24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dank24 »</TD></TR><TR><TD CLASS="quote">ah i went and bought a jdm d15b lol</TD></TR></TABLE>
well that should solve the problem
hurcombe
02-27-2007 06:07 AM
