difference between integ LCA & Civic's??
i busted one of my lca in the rear , so i replaced it with a 94up integ. now after installation it seems like that side of the car sits higher than the other? is there a diff between the 2? thanks
Re: difference between integ LCA & Civic's?? (allmotor.net)
I think the teg's is a bit longer and taller than the other one you had in your car. maybe by 1/2''.
Re: difference between integ LCA & Civic's?? (TrickHonda77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrickHonda77 »</TD></TR><TR><TD CLASS="quote">I think the teg's is a bit longer and taller than the other one you had in your car. maybe by 1/2''.</TD></TR></TABLE>
that's what I thought too but when I swaped my 95 civic rear suspension with 94 teg suspension (drum to disc conversion) I couldn't tell the difference. it looks exactly the same. btw my civic doesn't have the problem the original poster ask for.
Re: difference between integ LCA & Civic's?? (sleeperciv)
so you thought it looked like that, but you couldnt tell the difference, it looked the same? which one was it? was there a difference or negative? thanks, just want to know, because im going to do this swap.
Integra and Civic lca's share the same dimensions for location of the bolts that attach them to the chassis, knuckles and shocks.
But Integra lca's have bushings with beefier construction, as there is a metal inner layer between the bushing that makes them less likely to flex in comparison to civic lca's.
Civic front lca's share the same bushing size and Integras.
Civic rear lca's have a smaller bushing size compared to Integras.
you should see no difference when swapping over lca's like you did.... perhaps the upper control arm is bent as well? or a shock was damaged?
Re: difference between integ LCA & Civic's?? (Matt B)
Are ITR LCA's the same dimentions as GSR or CIVIC's (EG)....cause if you want ot up a TIR sway bar on can you use any teg LCA...or with the ITR change your track, cause the ITR did have a larger track no?
Re: difference between integ LCA & Civic's?? (T-Spec)
ITR rear LCA's are same length as EG/DC but different design so they require ITR rear shocks.
ITR swaybar can be used on normal Integra rear LCA
ITR track width is wider because of spindles on knuckles/hubs, not the "suspension"
NoLipRacen
07-07-2003 05:05 PM
