Difference between a Canadian EG and the US EG????
i was thinking about getting this canadian version 92 EG hatch its very clean and i was wondering if any of u guys out there can tell me the difference between the USDM EG and the canadian EG? the guy said it came factory with no AC also? any feedback will be appreciated. thanks in advance!
Re: Difference between a Canadian EG and the US EG????
i know some came with no ac. i think it was an option.when you mean by the difference between usdm and the canadian, do you mean where they were made?
yes it was made in canada and i just wanted to know whats different if anything significant to make it better or worse...
Oh look, I can change this
All 5th Gen EH2 and EH3 chassis code hatchbacks were made in Canada. Is this what you're asking, or are you asking about a vehicle that was destined for the Canadian Domestic Market (CDM) vs. US Domestic Market (USDM)?
Above is correct. Also, if it's a CDM 92 Si, it might not be equipped with SRS.
Last edited by deschlong; 07-12-2009 at 03:51 PM. Reason: Clarified that I meant 5th Gen CDM and USDM hatchbacks.
OP, if you are from Texas, why do you want a car from Canada? Just curious. I would rather have a car from the south than something put through 15 winters of ice, snow, and the wonderful salt.
bc the car is super clean no rust and 120,000 km and i may trade for it soo i was just wondering u kno.....south cars ftw tho f*ck salt
i have an EG from canada mine came with blue interior and some of rear interior that the Si has like the cargo cover, speaker covers ,the light in the trunk it was prewired for vtec and it didnt have any or that black tart fund under the carpet . ohh and no rust at all
I remember reading that all Canadian hatches had the 11.9 gallon gas tank while only a few of the usdm hatches had the 11.9 gallon tank most had a 10 gallon tank. I don't know if this is true or not just trying to help.
Another difference between the USDM EH and the CDM EH (EG is mainly JDM as far as I know). The CDM EH's don't have the Electric Load Detector (ELD) while the USDM EH's do.
Also as said above me, CDM has Daytime running lights, while USDM does not. And to repeat myself, the CDM does not have the ELD while USDM does have the ELD.
Neither my wifes CDM DX hatch nor my CDM CX hatch have AC. The DX has power steering while my CX does not.
Also, the USDM CX has the 12 valve D15B8 motor with the tall gearing manual transmission (like the VX), while the Canadian CX is the 16 valve D15B7 motor with the slightly shorter gearing in line with the DX (USDM or CDM) transmission on the manuals.
That's all the differences I am aware of, there is likely more that I am not aware of. I think deschlong may know them all, he amazes me consistently with his Honda knowledge.
My 92 USDM VX has the 11.9 gallon tank. I found that out pumping 10.4 gallons into it on one fill up.
I believe all 1992 USDM hatchbacks have 11.9 gallon tanks.
eH.
eH.
Seagull Management
No '92 Civic came from the factory with AC, not even the EX sedan. It optional and installed at a dealership level. The whole thing came as a kit. It wasn't until '94 that the EX sedan gained factory AC, and even then it was only the EX sedan.
US CX/VX and Canadian VX don't, if yours does it was swapped at some point.
eH.[/QUOTE]
If it's a real CDM Civic it most likely wont have an airbag. '93 - '95 Sis had standard airbags, but not the '92. I've seen exactly one '92 - '95 Canadian hatch with a factory airbag that wasn't an Si.
White CX, the rear speakers were available as an accessory on all '92 - '93 Civics, they were standard on '94 - '95 Sis only. Some '95 Canadian CXs came with a rear wiper as well.
eH.
eH.
eH.
Seagull Management
That's just simply not true, you can check the part numbers, if you look you'll notice the VX tank is no longer available, but the 11.9 gallon tank is if you check under other '92 models.
Someone swapped the fuel tank on your hatchback, or you had far less gas in it when you thought when you filled it up.
1992 Helms Manual
1992 Honda Civic VX Hatchback (since mid-year 1991 for North America U.S.) specs review
ABOUT CARS - The Civic VX - a Honda for the Long Haul - NYTimes.com
Honda Civic VX Gas Gauge - Fuelly Forums
eH.
I can find source for both the 11.9 and 10 gallon tank in 1992 on the VX, most likely the CX as well.
eH.
ej1bmx
05-08-2013 06:26 PM
