Did d series swap idle is bad
I pulled some codes from the dumby plug and i got 3 and 14 (Map sensor and IAC Valve)....so i took off the IAC and switched a plug in the bottom of it...before i did this the idle was unsteady and when i stepped on the gas the car would die...now the idle is high (2k) and it still wants to die is a step on the gas....if i SLOWLY step on the gas i can get the RPMs to rise....i then tried to pull some codes from the ECU after i reset it and the engine light stayed steady and the SRS light was blinking....whats the deal lol
Re: Did d series swap idle is bad (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">yeah, could have the IAC and MAP plugs reversed</TD></TR></TABLE>
They're two different types of plugs.
Re: Did d series swap idle is bad (JDM-SI Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-SI Sol »</TD></TR><TR><TD CLASS="quote"> light stayed steady and the SRS light was blinking....whats the deal lol </TD></TR></TABLE>
pretty sure that means u have no codes...i kno it did that when i was running some test on my car and i had no codes..but i jumped the terminals..
Re: Did d series swap idle is bad (WhiteOut)
ill have to check them again...i swithced around some plugs...it is driveable now...but the idle is still screwed...it idled around 1500 and fluctuates very quickly...like 1200-1600 back to 1200...very quickly
