Diagnosis help: 92 VX Check engine light stays on.
First of all, the car is completely stock.
I was told that it might be the o2 sensor, but I think that was replaced before I bought it or at least it looks like it has been replaced. Anyway, the car still drives, but it seems to be using a lot of gas. Almost like the vtec isn't kicking in properly.
Will the O2 sensor cause the check engine light to stay on?
Any help would be appreciated.
Re: Diagnosis help: 92 VX Check engine light stays on. (whoobeedoobee)
Yes very possible. Also I believe the VX has 2 02 sensors. Check the code, if it's a 42 I believe that's the 02 sensor heater, so replace it.
HT Black Ops
the VX only has 1 o2 sensor, but I had an o2 sensor go bad on my VX and it did turn the Vtec off. With the Vtec off the gas milage went down the tubes...
Do yourself a favor and swap that eninge( I did), you can't find any parts for that engine that are worth the $$.. The car is Sooo perfect for a swap( much better the a CX IMO) you already have a tach( no need for an ugly 5" tach) Turboing that engine is a very bad idea, the rods are very very thin.
But i do have to admit, that engine is tough as nails when it comes to reliabilty, I went over 18 months without an oild change just to see how long it would go, I have a 50 round trip to and from work 5 days a week!!!
Re: Diagnosis help: 92 VX Check engine light stays on. (92 civic VX B18c)
I agree with everything you said regarding the swap, I may at some point go with a b18c1. Prices seem to be coming down on them.
I bought the VX for the gas mileage. I got it from the original owner whose wife drove it back and forth to work. It is a little beat up on the exterior, but the interior is cherry.
R/g the oil change. That is too funny. In college, I did the same thing to a 91 Accord. When I got rid of it (100K+) later, the dash lights were blinking like a Christmas tree.
Thanks again for the info! BTW did your check engine light come on?
