Delsol vtec rad hoses for my swap?
Last weekend I swapped a b18b into my eg. I used the integra's rad hoses and jammed an inch or two of the civic's hose inbetween it and the fluid inlet/outlet on the civic's radiator. This seems to be working okay but I would feel much better if I had the proper hoses. Are the hoses on the b16 delsol vtec the ones I want?
Re: Delsol vtec rad hoses for my swap? (transpar_nt)
i heard the civic ones will work fine, well i hope they do, lol i dont want to have to spend anymore money, i'm doing the same swap
Re: Delsol vtec rad hoses for my swap? (SPNFEDEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ »</TD></TR><TR><TD CLASS="quote">i heard the civic ones will work fine</TD></TR></TABLE>
Did you hear that from me here:
https://honda-tech.com/zerothread?id=1460351
I really do want different hoses for my swap, but I also want to make sure I gave that guy the right info about the delsol's hoses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">
I really do want different hoses for my swap, but I also want to make sure I gave that guy the right info about the delsol's hoses.</TD></TR></TABLE>
nah, one of my friends, he put a LS in his EG, but then ppl say use a 94-01 LS lower and a 94 del sol vtec upper, or visa versa
Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">the other thing you can do is use your integra hoses and upgrade to a radiator that has 32mm fittings like delsol dohc vtec or a civic dohc vtec radiator.</TD></TR></TABLE>
I will be getting a delsol dual core rad eventually. I just want the hoses now to make sure my engine doesn't barf coolant and melt itself.
Modified by transpar_nt at 8:04 PM 12/11/2005
Re: (hatchi)
for my b swap in my civic i used a 90-93 lower teg hose for the lower and used the old civic lower 1 for the top. i cut it to fit on the rad then i heated it up and jamed it onto the thermo housing. it took a lot of heating and pushing like a ****, but ones it goes on and cools down that mother aint commin off, unless u cut a slit in it
works in a bind for sure
edit - that was with the stock CX rad too
yep b16 vtec hose will work
if youre replaceing rad hoses.. look at http://www.kingmotorsports.com/
samco makes good aftermarket hoses.. so does spoon.. but those are like 200-300$
On a del sol with gsr engine...
GSR upper hose. It will fit perfectly on the engine side... but on the radiator side, it is just slightly bigger (del sol radiator) than the inlet, so i used a hose clamp on the radiator side.
James
James
civics4lyfe
01-23-2009 02:34 PM
94hatchling
02-14-2006 01:32 PM
