delsol b16 to jdm gsr swap questions.
so my buddies car blew up the b16 that was in it.
we swapped in a jdm gsr and the issue we are having is the throttle cable from the b16 is wayyyyy to long.
any one know away to make it work.
or should i just get him to order the gsr throttle cable.
The Grumpiest
Re: delsol b16 to jdm gsr swap questions.
Maybe try it and find out?
Search next time. You aren't the first to do this swap.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/gsr-swap-del-sol-2583109/#post39475978
https://honda-tech.com/forums/showthread.php?p=39475978
The Grumpiest
You know the name calling is juvenile and absolutely uncalled for. Do you think that was the only search result? Here's another one.
http://htarchive.org/showthread.php?t=508721
Here's all of Google.
http://www.google.com/search?q=delso...ient=firefox-a
I don't really think you've searched hard enough.
...you managed to do an ENTIRE engine swap before noticing a cracked manifold?
you sure you were running the wire correctly in that case?
as far as i know all b series are interchangeable. if it was a b before it should work as a b now.
hybrid1990crx
06-05-2012 05:13 PM
