Del sol wiring problem
I just bought a del sol and am planning a b series swap, it is a 93 del sol s and it is automatic( im going to convert it to 5 speed) Would i be able to use an engine harness out of a 92-95 hatch, assuming it has the supplied knock sensors vtec wires and what not) also, would buying a del sol dohc vtec engine harness eliminate my problem as far as wiring from auto- manual, i cant find any info on this anywhere, any information is grealy appreciated and thank you in advance
Re: Del sol wiring problem (Mr. Em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Em1 »</TD></TR><TR><TD CLASS="quote">Would i be able to use an engine harness out of a 92-95 hatch, assuming it has the supplied knock sensors vtec wires and what not) </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Em1 »</TD></TR><TR><TD CLASS="quote">also, would buying a del sol dohc vtec engine harness eliminate my problem as far as wiring from auto- manual.
knock sensors only appear on the later model SOHC I believe. I never bothered to check… it’s not that hard to wire something, it’s the information that is hard to come by. soooo..... If it has a knock sensor, 1 less thing to wire. If not, check the FAQ ecu thread.
No, You’ll have to wire 3 things…
-always in park
-cruise control (if you have)
-reverse lights
correct me if I am wrong.
-always in park
-reverse lights
Re: (Mr. Em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Em1 »</TD></TR><TR><TD CLASS="quote">so buying a dohc vtec del sol harness would solve my problems/ make **** easier</TD></TR></TABLE>
it jus has vtec wires and a knock sensor... don't really need 2...
1. yes you can.
2. auto to manual swap EG chassis https://honda-tech.com/zerothread?id=1316692
we've already answered your questions, stop posting & get your *** to your garage. there is no best wire harness to use because they're pretty much all the same in some respect. go0go0go0go0go0g0og0 now~!
