Del Sol Will not turn over - Page 2 - Honda-Tech - Honda Forum Discussion
Old 03-24-2010, 06:42 AM
  #26
BlueVxIDelSlo's Avatar
Default Re: Del Sol Will not turn over
wouldnt that be the same as jumping the starter?
BlueVxIDelSlo is offline
Old 03-25-2010, 12:30 PM
  #27
well i got it to be able to turn over with the key again. jumped the clutch switch.. now just gotta find out why no spark still
Old 03-25-2010, 01:50 PM
  #28
delsolproblems's Avatar
When you listed your grounds, you didn't mention the valve cover ground. Make sure that one is hooked up.
delsolproblems is offline
Old 03-26-2010, 11:28 AM
  #29
still no spark
Old 03-26-2010, 11:48 AM
  #30
Get ahold of a maintenance manual and follow the directions for testing the ICM wires. It will describe how to test all of the ignition circuits when the ICM isn't creating a spark.
Old 03-27-2010, 01:44 PM
  #31
could it be the crank position sensor??
Old 03-27-2010, 08:55 PM
  #32
turbo_eg_b18c1's Avatar
could be i dunno i dont run one cause i dont like them lol but possiable it could be id find a good one and change it see if its it did u check the ground on the themostat housing ??? that make it not have spark
turbo_eg_b18c1 is offline
Old 03-27-2010, 09:14 PM
  #33
bb4_bkh's Avatar
me and you are having identical problems man. i'm trying to figure it out right now. i've been searching all around the internet all kinds of forums i cant come up with anything..
my thermostat housing ground is good, valve cover ground is good, i have an external coil and it's got no spark at all coming out of the distributor side of it. idk how to check the power going into it.. but my guess it the crank position sensor man i have a 95 h22a where the cps was in the distributor and an obd2 distributor where the cps was in the oil pump..
bb4_bkh is offline
Old 03-28-2010, 07:56 PM
  #34
h22a4_sol's Avatar
i wouldnt say its the cps cause i dont have one and dont have it bypassed and it runs fine.
h22a4_sol is offline
Old 03-29-2010, 07:09 AM
  #35
are you out of fuel?....just asking cause.......
TurboTron is offline
Old 03-29-2010, 03:58 PM
  #36
2wheelhunter's Avatar
fuel is full, grounds are there, checked ecu, main relay, coil, icm... nothing ttt
2wheelhunter is offline
Old 03-30-2010, 07:15 AM
  #37
pinggoy's Avatar
Originally Posted by turbo_eg_b18c1 View Post
there a switch right above the clutch peddle make a jumper wire and try it mine did that and theres a rubber bushing in there and it falls out and the switch gose rite through the hole and wont start
This only happen if the car wont turn over at all..your lights work, fuel pump will hummm and no turn over.. he's got some turn over.. so must be something wrong with ignition or electrical stuff(i have electrical stuff.)
pinggoy is offline
Old 03-30-2010, 07:25 PM
  #38
gonna try a diff. distributor and see if that does anything.
Old 04-03-2010, 10:42 AM
  #39
blake post ur solution next time...
SOLUTION: New distributor fixed the problem. The components we initially tried must have been faulty also.
Old 04-03-2010, 10:49 AM
  #40
Si-Rhc's Avatar
Having roughly the same issue on my Delsol, but im already 100% sure its the distributor or at least i think i am.
Si-Rhc is offline
Old 04-03-2010, 12:28 PM
  #41
lol i didnt have time to get on here yesterday or today yes, i swapped the distributors and it started up
Old 04-03-2010, 12:30 PM
  #42
we changed the icm, the coils, the cap the rotor, the main relay, all fuses, and checked all grounds so last thing to try was a diff. distributor
focus on one thing and go down the list and null out all other possibilities and you will eventually find whats wrong
  #43
thanks for all the help guys!
Old 09-22-2017, 04:39 AM
  #44
I have similar issues. My del sol stalled on me and it won't crank at all. I've been looking at the fuses in case its as simple as that. But is there any suggestions on what else could be the issue. I was driving the car for 3 days no issue, but then when making a k-turn it stalled out on me and wouldn't crank at all. All the lights turn on the inside, the battery is brand new, literally 3 days old. Body has 221,000 miles motor has 165,00 approx. the other parts on the car the previous owner didn't provide me with that information
eidrovo is offline
Old 09-22-2017, 05:13 PM
  #45
tamboo's Avatar
tamboo is offline
Old 09-23-2017, 02:50 PM
  #46
DEL-SLOW 1994's Avatar
Safety switch?
DEL-SLOW 1994 is offline
rnuts
07-20-2017 11:33 AM
Manfromatree
06-17-2016 01:15 PM
jgregg
04-09-2016 11:07 PM
philztheone
03-21-2016 04:44 AM
Quick Reply: Del Sol Will not turn over
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
