Del Sol - Whining noise from Steering rack?
Old 12-22-2014, 04:35 AM
philztheone's Avatar
Default Del Sol - Whining noise from Steering rack?
I'm having this problem with my Del Sol but it's intermittent and I only get it when the car is moving straight. It will start or stop when I go over a small bump (or not).
Old 12-24-2014, 05:51 AM
ek9_beast's Avatar
Default Re: Whinning noise, Steering rack?
Guaranteed it was low power steering fluid buddy. If its not low it can also be "burnt" fluid which needs replacement. Lastly, the power steering pump could be on its way out. Check in that order. Hope that helps
Old 12-24-2014, 06:25 AM
Former User's Avatar
Default Re: Del Sol - Whining noise from Steering rack?
Metal-on-metal squeaking noise? If so, check whether the wheel splash guard is bent and rubbing on the brake rotor. Also, check for worn brake pads. The wear indicator may be sounding.
Old 01-12-2015, 12:06 AM
A follow up note. First, forgive me, I did not give all details. I did not because I thought they were not relevant. Here they are. Recently I had a valve job done on this car. I did not do the actual head work but I removed and reinstalled the head. After this work, the speedometer's needle was now off by five to ten mph. Along with his variance came this intermittent noise. I'm now thinking the noise is coming from the vehicle speed sensor (VSS). The manual states there is a "direct link". Does it make sense? My plan is to simply disconnect the VSS's plug, take out the VSS then reinstall it. What do you think? Thanks.
Matyikaaa90
05-19-2015 01:06 PM
wilderness166
10-21-2010 01:19 AM
shady3260
27
12-02-2009 02:51 PM
civicdelsol33
12-22-2008 11:11 PM
Quick Reply: Del Sol - Whining noise from Steering rack?
