Del sol VTEC????
Old 02-25-2003, 08:13 PM
FullMetalJacket's Avatar
Default Del sol VTEC????
How can you tell if its a Del sol VTEC (b16a) from the outside of the car..Im talking factory B16a del sol..do they have diff brakes,spoiler or something that makes them different in appearance?..Just curious cause im interested in getting one..i dont want one thats a base model thats been swapped
Old 02-25-2003, 08:41 PM
Shpoo's Avatar
Default Re: Del sol VTEC???? (FullMetalJacket)
If you look at part of the vin# JHMEG2176RS the 3rd number digit let's you know for sure what model you're looking at.
4 = S JHMEG1146RS
6 = Si JHMEH6166RS
7 = VTEC JHMEG2176RS
[Modified by Shpoo, 5:43 AM 2/26/2003]
Old 02-25-2003, 08:46 PM
smnowell's Avatar
Default Re: Del sol VTEC???? (Shpoo)
I have also wondered this myself. I know the Del Sol VTECs have a DOHC VTEC sticker on the back-right of the trunk...but other than that I don't know how to tell the difference. That is a good piece of info about the VIN
Old 02-25-2003, 08:49 PM
dAng!
Russ713's Avatar
stock vtec front rotors are 10.5"
check tachometer redline
check under hood ----
to see if mounting studs for strut bar are on top of the fender wells. (factory has studs welded in)
dual core radiator
94/95's have b16a3
96/97's have b16a2
later model vtecs had option for ABS
Old 02-25-2003, 09:36 PM
93EH6
Guest
Posts: n/a
4 = S JHMEG2146RS
6 = Si JHMEG2166RS
Ok stop missleading people the letters and numbers that you can tell by are the 4th 5th and 6th
The S will be EG1
The Si will be EH6
The VTEC will be EG2
Old 02-25-2003, 10:13 PM
Shpoo's Avatar
Default Re: Del sol VTEC???? (BLACK DEATH)
How am I misleading people? Part of those vin. #s are from my VTEC Sol, I only used it as an example. The point of my post was that they can tell which model by that 3rd numeric digit in the vin. #... I didn't say anything about the rest of it. Thanks for accusing though.
Old 02-25-2003, 10:42 PM
93EH6
Guest
Posts: n/a
Ok i am sorry i just have never heard of that way of doing i only knew to go by the chasis code which is
S EG1
Si EH6
VTEC EG2
But thank you for giving me another way of checking
Old 02-25-2003, 11:01 PM
Shpoo's Avatar
No problem I guess we're both saying the same thing just different ways of looking at it.
Old 02-26-2003, 07:42 AM
delslow94's Avatar
id do what black death has stated...look at the chassis code which is found in the vin. its a much easier way IMO
Old 02-26-2003, 07:48 AM
Former Moderator
B18C5-EH2's Avatar
I fixed the VIN numbers on your post Shpoo.
Old 02-26-2003, 07:51 AM
Former Moderator
B18C5-EH2's Avatar
Oh by the way:
If you're asking about how to tell from a glance or at a distance, it's kind of hard to tell because the differences between the si and VTEc models are so subtle that they are easily confused.
Aside from the rear "DOHC VTEC" sticker that can be removed, the front brakes being bigger on the VTEc model is how I would tell, but some people aren't as good at guaging that sort of thing.
Jaymzbo32
12
01-27-2016 05:57 PM
meagainsttheworld
09-03-2006 10:55 AM
816d16
16
02-19-2003 08:19 PM
Notorious1GF
07-27-2001 12:49 PM
Quick Reply: Del sol VTEC????
