Del Sol Sorings and Camber Kit
Just curious as to what kinda springs/coilovers u guys r running and what kinda front camber kit (if any) u guys r running. I have Skunk2 camber kit up front and it used to rub against the upper shock tower on my older springs, i recently got another set of cheap springs to solve the problem but the drop wasn't all that far anymore because i was just planning to get rid of the car. Now i have decided to keep the car and start to mod it again and i would like to know what set up u guys r using and if u guys r havig any problems. Thanks guys.
Re: (j-bird)
tein ss dampers. no camber kit. 15" wheels w/ 195/50 tires
sitting about an inch lower than in this pic.
http://www.solsociety.com/albu...d.jpg
no rubbing with the wheel turned to lock but i do rub the top of the tires to the inner fender when driving very aggressive on roads with elevation changes...
Re: Del Sol Sorings and Camber Kit (S(J)O(D)L(M))
Apexi n1 w/ pillows, progress camber kit (which is basicly swivel(spelling>?) mounts and poly bushings, and shims for the rear. G|A|B 16X7 Wheels, custom braces, rear and top & bottum, poly bushings
Modified by TheShad0w at 4:48 PM 11/12/2004
