Del Sol Short Shifter
I am thinking of buying a Skunk2 short shifter, probably the Dual Bend one. What im worried about is that the length of the shifter, I saw this one video online and it was an after market shifter that was ALOT higher than the stock shifter in a del sol. I juss want some insight on this cuz i like my shifter at least stock high but prefferably lower. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Del Sol Short Shifter (delvic)
anybody????
it probably had a civic or integra shifter in it, because those sit a little taller then stock del sol shifters.
I have a 1993 Del Sol and I was wanting to do an engine upgrade what should I get?
Re: Del Sol Short Shifter (bigjon06)
i bought a civic shifter for my del sol and it was just as tall as stock
just grab it lower down the shaft when you shift for racing...
Re: Del Sol Short Shifter (MNEJ2GUY)
ok, a short shifter isn't meant to necessarily be shorter in height than stock. it's meant to shorten the throw. it's a lever.... what really matters is how much longer it is below the bushing (under the car). having a shifter that sits down in the boot does less than something stock height with a longer axis (like the skunk2)
Re: Del Sol Short Shifter (Dave421)
I have the dual bend Skunk for my Sol and it sits very high almost as if it were meant for a Civic, i'm getting rid of mine. Had a DC before but bearing split so I grabbed the Skunk one and am not pleased. Might get the single bend. Just my thoughts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigjon06 »</TD></TR><TR><TD CLASS="quote">I have a 1993 Del Sol and I was wanting to do an engine upgrade what should I get?
</TD></TR></TABLE> First off stop trying to jack this thread do a fucking search this has been covered so many times i cant begine to count! As for the short shifter i have a single bend one and it works just fine, dosent hit the exhaust in the least and sits pretty comfortable. It came with the car so i dont know what a stock one would sit but id imagine it would be right around the same. https://honda-tech.com/forums/images/smilies/emthup.gif |
Dont Put a integra Shifter of any kind in your Delsol Cause it will be Super Long, I just did that last summer and boy was I upset when the Shifter looked like one of those brand New Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 »</TD></TR><TR><TD CLASS="quote">ok, a short shifter isn't meant to necessarily be shorter in height than stock. it's meant to shorten the throw. it's a lever.... what really matters is how much longer it is below the bushing (under the car). having a shifter that sits down in the boot does less than something stock height with a longer axis (like the skunk2)</TD></TR></TABLE>
I realize that it isnt meant to be shorter, its juss that im more comofortable grabbing low than somthing hella long. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) »</TD></TR><TR><TD CLASS="quote">I have the dual bend Skunk for my Sol and it sits very high almost as if it were meant for a Civic, i'm getting rid of mine. Had a DC before but bearing split so I grabbed the Skunk one and am not pleased. Might get the single bend. Just my thoughts.</TD></TR></TABLE> Thanks for the advice on getting a single bend cuz I was still unsure which would be better........ And thanks for all the help guys https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif To bigjon06 start ur own post man geez............. https://honda-tech.com/forums/images...s/emthdown.gif |
