Del Sol Shift Linkage
Location: I put on my robe and wizard hat, NY...err Bay Area--->Texas
I was wondering if the Del Sol shift linkage would bolt up to other 5th gen civics. I'm under the impression that the actual shifter would probably be too long; but my main concern is whether the shift rod and extension rod would reach the tranny if bolted to the stock location under the center console.
Would you believe none of the junkyards i've gone to in NYC have the regular civic shift linkage?
TSPeed Factory
Re: Del Sol Shift Linkage (uszcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uszcrx »</TD></TR><TR><TD CLASS="quote">bump .. even the D-series linkages are totally different?? S n SI?</TD></TR></TABLE>
S and SI shift linkage are the same. d-series is d-series
Re: Del Sol Shift Linkage (someforlight)
Sorry bro, the system won't let me use IM.
Email me at halfanp@aol.com, how much are you asking for it?
The del-sol B-series shift linkage will not fit on the 5g civics without modification (royal pain in the ***... with the cutting and the welding). You will be much better off getting the teg linkage if you are doing a B-series in 5g.
Josh
Josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uszcrx »</TD></TR><TR><TD CLASS="quote">looking to see what shift linkage is for del sol d16y8 </TD></TR></TABLE>
you need the d series del sol shift linkage, the d series civic shift linkage is too long. I tried using the civic shift linkage when i bent my shift linkage, but it didn't fit and I had to buy new shift linkage. If you can't find a used del sol d series shift linkage, try http://www.hondaautomotiveparts.com.
teknics1
05-30-2005 10:54 AM
