Del Sol seats in '00 Coupe
*PICS*Del Sol seats in '00 Coupe
What's up. I am sure this has been covered and asked before, but I have been searching and can't find it. I just bought a pair of Del Sol seats and plan to put them in my Coupe. I was trying to find out what needs to be done to put them in. Do I have to swap the rails and if so do they swap easily? Someone please help. Thanks.
Modified by DCivic00 at 12:01 AM 6/8/2004
Re: Del Sol seats in '00 Coupe (DCivic00)
I'll throw a little more info out there on this one... as I've swapped del sol seats into my last 3 96+ civics... After you swap your stock civic rails (sliders included) over to the del sol seats, I usually like to remove the 'cross wire' (for lack of a better term) that connects the locking mechanism on either rail. Actually, just remove one end (there'll be a small sliding washer that you'll need to slide to the middle of the cable to remove the cross wire from the hole it goes through). Then take a pair of needle nose pliers and move the bend in that wire back (towards the center of the seat) about .5 - .75 inches. What you're doing is creating a little more tension on the 'cross wire' so that you don't have to pull the seat adjusting lever all the way up into the foam of the seat bottom to slide your seat forward or backwards. My roommate says that I'm ridiculously **** and should seek counseling, but I was pleasantly surprised at how easy it was to fix this and then how easy it was to adjust my seat position afterwards. Excellent seats by the way.
Re: Del Sol seats in '00 Coupe (atisvt99)
Ask an ye shall recieve:
https://honda-tech.com/zerothread?id=826594
EDIT: Saw you've got them done, but this will help for future reference.
Vice President/CEO
i did this just this weekend.. i did not however shorten my wire... i think i'm going to try that.. It was a very easy swap.. the 93 Civic HB seat rails fit like a charm.
Yea I used the Del Sol wire. Made a huge difference. I was having trouble with one of the nuts on the outside rail from the Del Sol seat, but I had the wrong size socket. Once I got it, had no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atisvt99 »</TD></TR><TR><TD CLASS="quote">same ones I've got...
did you try shortening that cable any?</TD></TR></TABLE>
Re: *PICS*Del Sol seats in '00 Coupe (DCivic00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCivic00 »</TD></TR><TR><TD CLASS="quote">What's up. I am sure this has been covered and asked before, but I have been searching and can't find it. I just bought a pair of Del Sol seats and plan to put them in my Coupe. I was trying to find out what needs to be done to put them in. Do I have to swap the rails and if so do they swap easily? Someone please help. Thanks.
Modified by DCivic00 at 12:01 AM 6/8/2004</TD></TR></TABLE>
these seats go great in a EM1. they sit so low, and its perfect.
i have them same seats in my car and i think them are so comfortable, and when you are corning, you just stay there..
That is pure beauty. I'm definitely going to start shopping for some now. They look so great, and having sat in them, they're awesome.
SLO_EH2
12-07-2008 02:54 PM
ether
06-22-2008 05:53 PM
