Del Sol rear Window Regulator
How do you access the rear window regulator? Frorm looking at online parts drawings it seems you go through the trunk.
I brought this car home yesterday and the window is stuck partially open.
Just wanted to check before I tear things apart.
Re: Del Sol rear Window Regulator
not getting to it from trunk without a torch.
View From the trunk
View from inside. The regulator and glass are mounted to the other side of the black panel. Removing the 10mm bolts around the edge releases the entire assembly.
BTW I found a broken cable.
View From the trunk
interested in what you did with that broken cable. my sol the window is stuck up and i got a busted cable. were you able to replace just the cable or did you have to do the whole mechanism?im semi lucky(at the cost of rigidity) old owner chopped out a good square foot n a half section from the trunk so i can actually see in from there. but no way i can replace the whole mecanism from there, wont fit out.
OxDseries
08-18-2016 03:35 PM
SilverGT
01-28-2007 10:26 PM
