Del Sol purchase tips
Old 03-21-2005, 02:59 AM
Dirrrty T's Avatar
Default Del Sol purchase tips
Can anybody tell me what to watch out for if I wanna buy a sol? Been dreamin bout one for years, and wanna get it soon!
Old 03-21-2005, 03:25 AM
zephyrantes's Avatar
Default Re: Del Sol purchase tips (Dirrrty T)
one BIG tip that I wish I knew was removing that plastic(?) lip around the rear wheel wells... you'll see it. It's a black piece right above the rear tires that goes over the lip. A lot of moist dirt builds up there which forms rust.
Also, check the outer edge of the door jambs. Look at the car with the doors closed. The little space between the door and the quarter fender is normally plugged off by painters using a foam tape. When you open the car doors run your finger along that area (am I making sense so far?). If the paint is rough from top to bottom, then the car has been repainted before. It's a good tell-tale sign, apart from other little things.
Old 03-21-2005, 03:46 AM
Dirrrty T's Avatar
Default Re: Del Sol purchase tips (zephyrantes)
Making sense and a lot more info than I've got before...
Just want to be sure not to buy somethinbg I won't be happy bout after. And as I am a girl, guys that sell em try just bout everything....know my civics and stuff, but haven't gotten into the sol to deep yet.
Old 03-21-2005, 03:57 AM
modedicebox's Avatar
also check all the gaps between the fenders and doors.doors and rear quarter panel. Look at the core support around the headlights to make sure there no signs of an accident.Also drive it make sure its tight.Good luck
Old 03-21-2005, 04:07 AM
Dirrrty T's Avatar
Default Re: Del Sol purchase tips (modedicebox)
So what you think how many m or km 's it can have without bein totally done?
Old 03-21-2005, 04:15 AM
i wouldnt worry about mileage to much you know its a Honda
but make sure it still runs good no smoking or leaks or anything of that nature.
Old 03-21-2005, 04:30 AM
soLSvtec12kcraze's Avatar
make sure it has VTEC.
Old 03-21-2005, 05:03 AM
JohnnyLux's Avatar
Default Re: (soLSvtec12kcraze)
try to test drive it on a nice day and a rainy day or just take it to a car wash and check for roof leakage. i wish i had done that...
Old 03-21-2005, 05:30 AM
Evil-EK's Avatar
Default Re: (civic90)
dont bother checking for leaks. It's a delsol. It's gonna leak. Other than that you should enjoy your car.
Old 03-21-2005, 06:15 AM
Del Sol SiR's Avatar
you can find additional info on http://www.solsociety.com
Old 03-21-2005, 07:40 AM
HondaTechdotcom's Avatar
Just make sure it's an SI or SI V-TEC
the S model is a dog!
I had one... the S model
If ever buy another it will be an VTEC model!
Old 03-21-2005, 07:41 AM
IHateJDM's Avatar
Default Re: Del Sol purchase tips (HondaTechdotcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTechdotcom &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure it's an SI or SI V-TEC
S model is also the lightest if you are gonna swap anyways.
Old 03-21-2005, 08:15 AM
Ragecloak's Avatar
The 94 models they had a recall on the tops leaking bad (i can vouch for that one)...apparently it was fixed in 95 but i dunno
i like the look of the 93-95 models with the extra aux lights. I wish i would have got a 95 vtec instead of a 94 si though. The si has vtec, it's just sohc vs the vtec trim which is dohc.
Old 03-21-2005, 08:23 AM
Default Re: (BigBlockH22atch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch &raquo;</TD></TR><TR><TD CLASS="quote">dont bother checking for leaks. It's a delsol. It's gonna leak. Other than that you should enjoy your car.</TD></TR></TABLE>
my **** dont leak.....only cause i siliconed it....
Old 03-21-2005, 11:54 AM
Default Re: Del Sol purchase tips (93delslo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93delslo &raquo;</TD></TR><TR><TD CLASS="quote">
S model is also the lightest if you are gonna swap anyways. </TD></TR></TABLE>
I agree if gonna swap anyways.... guess it dont matter
Just a preference
Old 03-21-2005, 12:12 PM
POE
POE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze &raquo;</TD></TR><TR><TD CLASS="quote">make sure it has VTEC.</TD></TR></TABLE>
that was fucken gay!
IM me if u have any question's. You have a lot to learn before u can go out and look at a car and tell if its good stuff or trash. need to see if it burns or uses any oils, take it for a drive see how it shifts and what not. also check cv boots inside the front wheels. turn the wheel all the way to one side then look under the car inside the wheel and see if the boot is torn or cracked. also, look and inspect the motor for any OIL leaks or any wierd sounds with the car on and the hood open. If the car's motor and body has been taken car of it can last your up to 300,000 miles.
if the oil was changed regulary i wouldnt be worried about the miles, until after 150k. u got any guys that know anything about cars, that could go with you and check it out?
Old 03-21-2005, 12:15 PM
you're gay.
it doesnt make sense to get anything other than VTEC...id buy a shell of a sol before i would buy an S....and Si maybe cause it has power options and better brakes. but thats just my opinion.
Old 03-21-2005, 12:18 PM
POE
POE's Avatar
maybe it is a girl who just wants the car for looks, and she doesn't need vtec, anyways she is probably smart enough to know that the SOHC vtec isnt even that big of a deal. and not a waste of her money.
your comment just sounded DUMB to me like
FAST AND FURIOUS ****
Old 03-21-2005, 12:20 PM
oh. well i drive a sol. i was giving personal advice dude damn.
you probably wouldnt know where you dont even HAVE it.
Old 03-21-2005, 12:24 PM
POE
POE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze &raquo;</TD></TR><TR><TD CLASS="quote">oh. well i drive a sol. i was giving personal advice dude damn.
you probably wouldnt know where you dont even HAVE it.</TD></TR></TABLE>
I dont have what? vtec is this a fight over who has vtec and what not. btw. i did a mini me swap i have a d15b7 block with d16z6 head and IM and EX tranny, I/h/e 59300 camshaft valve springs, uberdata soon to be tuned.
Old 03-21-2005, 12:26 PM
oh....alright....just saying its better to buy a car with VTEC already in it.
Old 03-21-2005, 12:27 PM
POE
POE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze &raquo;</TD></TR><TR><TD CLASS="quote">oh....alright....just saying its better to buy a car with VTEC already in it. </TD></TR></TABLE>
maybe if the price is right. and its a legit car/motor.
Old 03-21-2005, 12:35 PM
dohcdelsol's Avatar
Default Re: (POE)
Many delsols are known for having some aux lights out. Ive never seen one that hasent with out being fixed.
Old 03-21-2005, 01:22 PM
never had a problem with mine.....?
Old 03-21-2005, 10:26 PM
Ragecloak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze &raquo;</TD></TR><TR><TD CLASS="quote">never had a problem with mine.....?</TD></TR></TABLE>
i second that. Course i got some of 8500k bulbs that're bluish looking and the auxs are a brownish color, so now i leave the aux's off. I miss them too cause it looked cooler with them on and the 8500ks dont provide a whole lot of light
Quick Reply: Del Sol purchase tips
