Del Sol with GSR Swap/exhaust manifold. EG exhust?
Normally no one makes exhaust for the del sol. RS-R inparticular was the one that I was looking at for the stealth look, quality, and sound (of lack there of). Anyways, many people have said to just go ahead and trim a little off of it and then the EG exhaust will work (since all the hangers are the same) Well, I just finished a GSR swap, and as you know, the GSR swap leaves a foot gap between the Cat and the catback. So What I was thinking, Would a un-moded EG exhaust bolt right onto a sol with a GSR swap. Would the gap be filled, or would it be filled and them some?
Well I'm not really sure about the eg exhaust fitting in, but I don't think it will work quite right. The gap for the gsr is only 4.5 inches not a foot.
I just finished puting a gsr into my sol S. I used stock gsr downpipe and cat. There was only a 4.5 inch gap between cat and stock S piping. IF the EG piping is just a bit longer it may work. If the eg piping won't directly fit, you could always have a small pice of pipe made up. I cut the flange of my S cat and used the flange from the gsr a pipe to make a small piece that would bolt right in.
724chris
03-08-2010 04:35 AM
Del_Sol_s
07-31-2005 03:29 PM
civicEXcellence
11-05-2003 07:37 PM
Gixxer_Rich
11-11-2002 01:53 PM
