Del soL ECU Q w/ H2b setup
Hey i have a question correct or not I can use hasport motor mounts for the H2b setup ? and i have a 94 delsol s.i. single vtec is that P28 ? P72? and whichever it is can i use that with the h2b setup ? it would help alot for some info thanks guys
yes you can use hasport mounts or stock mounts, the stock single vtec ecu is the p28. You can use the p28 if you have a h22 basemap put on if not you can use the gsr p72 ecu and turn up the fuel a little using a fpr so it doesnt run lean.
S2K Luver
12-04-2006 01:45 PM
