Del Sol DOHC mods
Del Sol DOHC mods
Im rebuilding my 94 del sol...its the vtec dohc... any suggestions of some sweet mods i can do while im down there.. got a cold air and headers and new exhaust already? Anybody know anything else i could add to get some more power?
Thanks
Thanks
Re: Del Sol DOHC mods
What's your power goal? You won't make much with just bolt ons.
To get some real numbers you'd have to build the motor internally or go with forced induction.
I ordered new ctr pistons that have a 12:1 cr....i would like to get at least 200 hp so i wont need much more cause im think ill have like 190 after the rebuild.... just wondering if there was anymore things i could do without spending a ton...
The Grumpiest
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/can-we-get-official-b16-all-motor-dyno-thread-2466663/
And you still won't have any torque.
Ha considering its 160 hp stock, pistons and my few bolt ons wil allmost get me to 190... bhp i am aware....i feel like gettin to 200 wouldnt be as hard or as much as your saying
lol. OP are you talking about crank HP or WHP? big difference...
b16 stock has about 135-140 WHP
and what exactly are you rebuilding...do you know what you doing? have you done it before?
without involving a machine shop too much you could do the following
get bigger cams( ctr or ITR cams are very popular choice for b16)
get ITR dual valve springs for the intake and move your intake springs to exhaust side(for the above cams only)
2 upgrade to an aftermarket intake manifold like skunk2 or performerx or even an ITR intake manifold and throttle body
buy flat faced supertech valves and use thinner headgasket to raise up the compression.
can also mill the head to raise compression
by the time you are done you could have just bought a gsr swap with boltons and have same power and much less headache.
but for the engine building experience is great cuz b16 are not that expensive to replace and still make good power for what they are 1.6 liter engine
Crazy Honda Guy
For what it's worth, i don't think a B16A is worth building up these days....why? Because, if you search around a bit, you can find a deal on a B18C block for cheap, even if it needs rebuilding, it's worth buying.
I have done it a few times. Buy the long block and sell off the head, or even just find a short block. Bigger engines make more power, right out of the box....plus "torque" is a nice thing to have
Agreed with everyone else on here. Turbo it or save money for something else. I have a B16a2 and would definitely use a B18 or B20 for all motor build. But since you already bought pistons... I would just build the motor to accept as much nitrous as possible IMO. If you didn't want to turbo it that is.
shm91
11
01-21-2013 10:47 PM
turbomonkeyexpress
02-17-2003 08:45 PM
