Del sol 3rd gear grind!! Help
Old 04-11-2013, 10:14 AM
DelSol-B18's Avatar
Default Del sol 3rd gear grind!! Help
B16 always grinds going into third low Rpms or high Rpms. This only happened after I changed my mounts to stiffer mounts and running a stage 4 clutch. I even changed trannys and it still does it. Also I'm running a synchromesh too. If I shift fast it grinds but if I depress the clutch and wait a few seconds it won't grind going into third. What could be my deal here??
Old 04-11-2013, 11:11 AM
Emeraldbomber's Avatar
Default Re: Del sol 3rd gear grind!! Help
It does it in no other gears? just 3rd?
Old 04-11-2013, 01:14 PM
DelSol-B18's Avatar
Just third
Old 04-11-2013, 01:19 PM
B_Swapped93's Avatar
You might just have 2 bad 3rd gear synchro's my gsr 3 and only 3rd grinds. don't suppose you have a 3rd trans lying around you could try
Old 04-11-2013, 01:22 PM
sleepyaccord96's Avatar
by replacing the motor mounts...it would not have caused the trans to all of a sudden start grinding going into 3rd, regardless.
Old 04-11-2013, 01:45 PM
DelSol-B18's Avatar
Yeah idk this is weird
Old 04-11-2013, 01:47 PM
Hamza_Z'sTuning's Avatar
Is the clutch properly installed?
Old 04-11-2013, 01:48 PM
Freemananana's Avatar
I've heard the B series has a knack for 3rd gear grinding.
Old 04-11-2013, 01:49 PM
Yeah my cousins ls vtec always had a problem with the b16 tranny...
Old 04-11-2013, 02:10 PM
DelSol-B18's Avatar
Clutch is installed fine.
gabe768
06-07-2010 03:06 PM
johnnyare
02-12-2010 03:13 AM
Aber
13
12-07-2009 11:21 PM
oneEg1Tc
14
04-15-2009 07:56 PM
hondafrk
06-29-2002 10:53 PM
Quick Reply: Del sol 3rd gear grind!! Help
