99 Civic Ex isn't starting
Recently been having trouble with my car. My car battery keeps getting drained could this be caused by my distributor? I think it went bad. Its an aftermarket one.
re: 99 Civic Ex isn't starting
Distributor will not do that.
The first check to make is to measure the voltage at the battery with the car running to see if the charging system is working.
Old Fart
Ditto the above, check voltage at batt. with engine off then running, must be done with fully charged batt., if good, about 12.5 not running and no more then 14.5 when running.
If good, do a parasitic drain test.
To do a parasitic drain test all you need is a 12V test light, [not the LED type] disconnect the neg. batt. lead and connect the test light ground to the batt. cable and the test light probe to the batt. post, test light is in series
Make sure everything in car is off, if the test light lights up you have a parasitic draw, something is staying on and drawing power, you will need to find it, pull fuses, one at a time, until test light goes out and you have found the circuit 94
Old Fart
Sounds like you have more then one problem.
When you say no start, what do you mean?
Engine cranks but will not start or it will not even crank?
MM&Y of car and auto or 5speed? 94
No start but cranks
My 1999 Honda Civic Ex isn't starting
It all started one day when my car wouldn't turn on my battery had been drained so i took my battery to my local autozone and they charged it for me and when I got the battery back I put it in my car and car started right up ran it for 20 mins and then parked it. Well the next day I try to turn my car on and it wouldn't start so I decided to take the battery one more time to autozone to get it charged and again I put it back in my car but only this time the car didnt fire up. I checked my battery with my multimeter and I'm getting 12.2 volts. I checked to see if I'm getting a drainage with my test light and I'm getting zero drainage. At this moment I'm confused.
What should be the next thing I look into? Thanks in advance
Re: 99 Civic Ex isn't starting
Would it be this diagram?
And my car is manual btw.
Check them all.
Especially the tranny to chassis one. T4, engine ground cable B.
If its green or corroded, it will give u issue.
My fuel is a bit low but I dont think that can be the cause of it anyhow I will put some in just to check that off the list. As for the fuel pump I do hear it prime
Old Fart
Check for power at the injectors, with ign. in both the run and start positions, you can unplug the exciter lead from the starter to prevent engine from cranking while testing. 94
Checked injectors with my test light and it checked out. I also took out the spark plugs to check them and this is the condition they are in another thing was when I took them off I got the smell of fuel in the engine Im not sure if thats normal?
I also forgot to mention that I checked my fuses underneath the dash and when I went over the starter switch fuse which is a 7.5 it wouldn't light up my testlight could that possibly be the cause?
This all started after a rained about a week and a half ago.
If you mean fuse 31, it provides a starter signal to the ECU. It only gets voltage with the key in ON(III).
This is how my timing belt looks, I have totally ran out of ideas of what It might be Time to take her to a professional thanks to everyone who helped I appreciate it
