deciphering VIN codes?
i got a swapped eg hatch,and i found the vin plate on the trans and it reads:
JH4DC4354YS013954
the trans has s80 on it,can anyone read this vin and tell me what it came out of so i know for 100% thats its no a LS trans wich im almost sure its not,too short geared!
JH4DC4354YS013954
Re: deciphering VIN codes? (92egcivicls)
I was wrong
Free Record Check Results:
VIN JH4DC4354YS013954
Year/Make/Model: 2000 ACURA INTEGRA LS
Body Style: HATCHBACK 2 DR
Engine Type: 1.8L L4 PFI DOHC 16V
Manufactured In: JAPAN
Search Results: 15 records found in our database What is a Record?
IMPORTANT! The 15 records on this 2000 ACURA INTEGRA LS may confirm a clean title history or uncover potential problems. Find out by ordering the complete CARFAX
Re: deciphering VIN codes? (Rok_Stok)
why is it so short geared,lol?
i cant get past 80 mph shifting at 7700 to 7800 rpms in 3rd gear?
52 mph into 2nd shifting at 7800,wtf?
at 70 mph in 5th im at 3500 rpms?
so excuse the ignornace,lol its a jdm trans right?
watch this video here is what im talking about,lol
right click save as:
http://www.plastikhosting.net/...3.wmv
What you're describing is the same gearing as a 98+ JDM ITR S80 tranny with the 4.785:1 FD. Yes it's also called a S80, but this doesn't explain that VIN plate. And technically you're at 54.02mph @ 7800rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">In some cases trying to ID a B-series tranny is not always possible from it's external markings. So how can you tell?
This is what i have found to be the easiest method of doing so.
First you have to start off by taking the outer casing off. Fortunetly we already have a how to on that subject thanks to Plan B: How to: Take Apart a Transmission
Now that you have it apart. You can either go a step further and remove all the internals to be able to count every gear, or just get a tooth count on the final drive gear, it's opposing gear located on the counter shaft, and the upper most gears on both the counter and main shafts to calculate the transmissions 5th and final drive gear ratios.
Once you have counted how many teeth are on each gear, you need to divide the number of teeth on the counter shaft, by the number of teeth on the main shaft to find the gear ratio. I'll give you an example using the transmission pictured. **
There are 25 teeth on the upper most counter shaft gear and 35 teeth on it's opposing gear located on the main shaft. If you divide 25 into 35, you come out with a .7142857 (.714) ratio, which is the 94+ LS transmission's 5th gear ratio.
Now using the same method, you can find the FD ratio by counting the teeth of the final drive gear, and then dividing that by the number of teeth of it's opposing gear located on the counter shaft, which would be 64 / 15 = 4.26666666 (4.266). The 94+ LS transmission's final drive ratio.
Here is a list of B series tranny gear ratios for reference purposes:
The information in this chart is for reference only, and may not be 100% accurate in all cases.
or you can use this:
http://www.bseries.net/html/specs/btrannyspecs.php
Well that's about all there is to it. Hope this is helpful to some of you...
Modified by JV at 8:07 PM 5/3/2004</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92egcivicls »</TD></TR><TR><TD CLASS="quote">ok im off a few mph but that a far cry from the 66 to 67 mph the ls trans has,lol</TD></TR></TABLE>
Exactly. The LS would be at 67mph @ 7800.
@7800 rpm.....
LS= 67.13mph
GSR= 65.09mph
B16/ITR= 58.75mph
98+ITR= 54.02mph we have a winner! That's a nice tranny.
@7800 rpm.....
LS= 67.13mph
GSR= 65.09mph
B16/ITR= 58.75mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92egcivicls »</TD></TR><TR><TD CLASS="quote">lol im not ready to tear the trans apart to count it,maybe when i install a lsd,lol</TD></TR></TABLE>
Okay... do you know if you have a LSD? That would answer alot of questions.
no i dont and im not gonna pull axle to tell,wheir is the "lsd" marking on the casing of the trans?underneath?
or tell me how to get the front end up in the air with both tires off the ground with my floorjack and i will go check now,lol
Modified by 92egcivicls at 11:07 PM 10/31/2008
Have you done a burnout and there were two skid marks, not just one? That would mean you have LSD.
The tranny we think you have comes with LSD from the factory.
Has an aftermarket Final Drive been installed into your tranny, or is it from what you know stock?
well from past experinces i know thats not the way to tell,lol
ive had open diff's in fwd"s that would torch both tires 95% of the time and leave 2 marks.lol
then put a quaffie in only to see the samething!.lol
its when its truly under LOAD that you can tell, like in a burnout box with water.
wheir do i jack from to get the front end in the air at the same time and ill turn one of the wheels,and see what the other one does,lol
im new to hondas but not new to FWD racing
also the itr seems to short geared,im at 3500rpms in 5th gear at 70 mph,lol?
nothing is making sense ,hence why im asking ,ive done my searching,lol
That's a 0.787:1 5th gear w/ a 4.4:1 FD. That's probably a GSR tranny. A LS would put you at 80mph at 3500rpm.
Haha, wtf.
Haha, wtf.
From what I understand, all of the JDM/EDM Integra 2-drs were either DC1 or DC2.
The USDM LS, GS, RS, and SE is a DC4. And since the VIN came back as a 2000 Acura Integra LS, I would say this is a USDM tranny. They didn't have LS models in Japan, they were called Ti, Xi, and Xi-G. Plus they didn't have Acura in Japan, although Acura Integras were built in Japan.
The tranny could have been rebuilt with GSR gears. That's all I've got left.
Modified by Rok_Stok at 12:02 AM 11/1/2008
