Dealer says never change your fuel filter?
Old 10-29-2003, 03:02 PM
ramz7887's Avatar
Default Dealer says never change your fuel filter?
I figured i would change my fuel filter since my car has 110xxx miles on it. I figured its got to be dirtly maybe i'll free up some power and fix my low idle problem. I think its the 02 sensor though and i'm going to change that friday Well a asked a dealer a question about how to remove the filter and he told me that honda filters are good for the life of the car. I don't know if he's right because he also told me that honda's have mass air flow sensors.
Old 10-29-2003, 03:08 PM
built562's Avatar
Default Re: Dealer says never change your fuel filter? (ramz7887)
well unless something has changed i was always told they are part of routine maintance at either 30/60/or 90k miles, so i change mine about every 30 thousands to be safe, to change mine i would use 2 box wrenches on the bottom, one to hold the hex on the filter and the other to turn the fuel line fitting.
Old 10-29-2003, 03:13 PM
ramz7887's Avatar
Default Re: Dealer says never change your fuel filter? (akumaracer)
He said not to change it unless you get a cel for it.
Old 10-29-2003, 03:27 PM
FcUK It.'s Avatar
i changed mine and it seemed like my car ran better
Old 10-29-2003, 03:31 PM
endlesswinterco's Avatar
im a auto tech, we change fuel filters for all of our cars every 35k. dealerships always trying to screw people
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 &raquo;</TD></TR><TR><TD CLASS="quote">He said not to change it unless you get a cel for it.</TD></TR></TABLE>
Ummm...so you would'nt change your oil until you started having problems because of it. It's like 20 bucks, so just go ahead and change it as part of your maintenance.
Old 10-29-2003, 04:29 PM
Smith Wise's Avatar
Default Re: Dealer says never change your fuel filter? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Ummm...so you would'nt change your oil until you started having problems because of it. It's like 20 bucks, so just go ahead and change it as part of your maintenance.</TD></TR></TABLE>
change it man, it's one of the easiest things to do..... it's sitting right there, you don't have to do anything else but relieve the fuel pressure, and yeah it's only like twenty bucks.....
Old 10-29-2003, 04:38 PM
ramz7887's Avatar
Default Re: Dealer says never change your fuel filter? (Jswpstdoff)
my fuel filter from the dealer cost 36 with tax. And that damn bolt on the bottom is a pain in the *** to get off.
Old 10-29-2003, 04:39 PM
madman604's Avatar
get a new dealer IMO.
Old 10-29-2003, 05:15 PM
EL Vap133's Avatar
If you never replace it, one of these days your car will not start cause it's gonna be clogged up...
Old 10-29-2003, 05:20 PM
AL ASPIRATED's Avatar
i agree with Turbo E
Old 10-29-2003, 06:14 PM
Smith Wise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 &raquo;</TD></TR><TR><TD CLASS="quote">my fuel filter from the dealer cost 36 with tax. And that damn bolt on the bottom is a pain in the *** to get off.</TD></TR></TABLE>
just use two open ended wrenches
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer &raquo;</TD></TR><TR><TD CLASS="quote">to change mine i would use 2 box wrenches on the bottom, one to hold the hex on the filter and the other to turn the fuel line fitting.</TD></TR></TABLE>
like he said.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">get a new dealer IMO.</TD></TR></TABLE>
or at least stop listening to them and asking for their advice...... and don't let them touch your car.......
Old 10-29-2003, 06:19 PM
ramz7887's Avatar
yeah i need to go and buy some wrenchs all the ones i had were too small. I think when i do it i'm going to take it out of that holder from the fire wall and take off my intake so i can get good leverage. I tryed loosing the nut with a cressent wrench and i couldn't get in there. I'll do it friday when i cange my 02 sensor. Any thing i should know about that or is it just screw the old one out and put the new one in?
Old 10-29-2003, 06:21 PM
Smith Wise's Avatar
know how to relieve the fuel pressure??
Old 10-29-2003, 06:23 PM
ramz7887's Avatar
yeah you unscrew the gas cap.
Old 10-29-2003, 06:28 PM
KRiS1's Avatar
Default Re: (Turbo E)
Old 10-29-2003, 06:30 PM
Smith Wise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 &raquo;</TD></TR><TR><TD CLASS="quote">yeah you unscrew the gas cap. </TD></TR></TABLE>
and........... pull the fuel pump fuse and start the car and let it run until it stalls.... should only be a few seconds....... then remove the gas cap......gas will spill out of the filter, but definitely not a lot..... kind of like oil spilling in an oil filter.... good luck
Old 10-29-2003, 06:49 PM
ramz7887's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff &raquo;</TD></TR><TR><TD CLASS="quote">
and........... pull the fuel pump fuse and start the car and let it run until it stalls.... should only be a few seconds....... then remove the gas cap......gas will spill out of the filter, but definitely not a lot..... kind of like oil spilling in an oil filter.... good luck</TD></TR></TABLE>
which one is the fuel pump fuse? What about the torque on the bolts? I figured just tight so that no fuel leaks.
Old 10-29-2003, 06:51 PM
and........... pull the fuel pump fuse and start the car and let it run until it stalls.... should only be a few seconds.</TD></TR></TABLE>
****, when I pull the fuel pump fuse my car won't crank at all. Check under the dash and the little thing should have a label as to which one the fuel pump fuse is. Just put a towel over the top banjo bolt so when you crack it loose you don't get fuel on yourself.
Old 10-29-2003, 06:54 PM
ramz7887's Avatar
When i took off the top bolt a little fuel came out and that was with out doing the other stuff. I couldn't get the bottom bolt off but i figured with the pressure released from the gas cap fuel would not spray out.
Old 10-29-2003, 06:58 PM
If you have the top open it may leak some more fuel, but it won't spray.
Old 10-30-2003, 08:20 AM
JICEK9's Avatar
Default Re: (RidinlowHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">dealerships always trying to screw people</TD></TR></TABLE>
if the dealership as trying to screw you, wouldn't they sell you a part you don't need?
not tell you you don't need it. how would they make money?
Old 11-12-2003, 08:13 PM
integra-modder's Avatar
Default Re: (JICEK9)
they are called stealerships for a reason....
dont listen to the dumb ****
http://69.53.28.141/maintenance.html
look at the last line on that page...
Old 11-12-2003, 08:50 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">
not tell you you don't need it. how would they make money?</TD></TR></TABLE>
to sell more expensive parts and/or a whole new car later on down the line. Either that or the guy at the dealer didn't know what he was talking about. It should be in the regular maint. schedule. It's not like changing it will hurt, but not changing it might.
Steve
Old 11-13-2003, 08:43 AM
JICEK9's Avatar
Default Re: (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
Steve</TD></TR></TABLE>
agree- change it every 30k
Quick Reply: Dealer says never change your fuel filter?
