Dancing Tachometer... HELP
I noticed my tacho needle jumping to and fro when having reached 6,000 revs Up to 8,000, 9,000, back again to 6,000 and so on.
Can somebody help me???
Re: Dancing Tachometer... HELP (SiREG6)
Check the connections on your Ignitor in the Distributor. I had a similar problem with some other symptoms also, one of the four plugs on the ignitor was loose.
Re: Dancing Tachometer... HELP (splitime)
crazy slipping clutch?
i'd laugh with you at such a crazy suggestion, but it happened to by brother. i doubt this is your problem though.
I had a loose ground wire when this happened to me. It was only at 1-3K RPM tho.
My ground wire in question was by the distributor. Let us know!
Re: Dancing Tachometer... HELP (hanson said)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hanson said »</TD></TR><TR><TD CLASS="quote">crazy slipping clutch?
i'd laugh with you at such a crazy suggestion, but it happened to by brother. i doubt this is your problem though.</TD></TR></TABLE>
I am not stupid my friend!!
stockegsix
07-28-2005 06:16 AM
