damned sqeaking noises
hey H-T'ites.
Right now, I have 2 seperate sqeaking issues going on with my car and wanted to chat about them, throw them out there, get them off my chest sort of thing. One I know is directly related to me changing out my water pump this past weekend. On initial start up, there is a high pitch squeaking sound which I know is coming from my belts. However, the belts are less than a year old, and when I put them back on, the tension on them is what I would call medium. It gives a little but not too much. I was wondering when belts normally squeak, is it because they are too tight or too loose??? both? I guess I just need to start adjusting them and see what happens. ==== The second squeaking problem has been going on for a couple of months now, which now that I think about it may have something to do with my water pump too. During most (but not all) turns to the right, there is a high pitch squeaking sound that will last pretty much throughout the turn. It does it with and without the brakes on. And when I brake normally, there is no sound. I read an archived post about it maybe being the power steering pulley but my car has never had power steering. But again, its been going on for a couple of months and I would bet my water pump may have been leaking that long before I discovered it, so I suppose it's possible that the wetness may be a factor in this cursed problem. Any ideas as to what it could be causing the squeak during turning though?? thanks for the effort in reading this post and typing any kind of response. I know we are all busy and it sucks to waste time on stupid shit like this. Thanks again. |
Re: damned sqeaking noises (jefe)
ttt
does it go away when u put in the clutch?
if so then its probably the throwout bearing, mine squeaks all the time.. put in an old one when i put in my clutch.. baaaad idea |
Re: (Tad)
bump
Re: (jefe)
bump
Re: (jefe)
i know someone is just dying out there to talk about squeaking...come on
bump |
Re: (jefe)
ttt
Re: (jefe)
I think my wheel bearing sqeak when I have my wheel spacers on. Pretty irrelevant, but it's about squeaking https://honda-tech.com/forums/images/smilies/emthup.gif free bump I guess
i actually had several problems with my water pump when i had it inspected and replaced.
Turned out that two of the water pumps that were replaced were defective. Luckily the guy who worked on it for me replaced it 3 times free of charge due to a warranty on the service. https://honda-tech.com/forums/images/smilies/emthup.gif he also noted he wasn't sure what was going on, but i had a high-pitch squeaking/whistle at idle...extremely annoying |
Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">does it go away when u put in the clutch?</TD></TR></TABLE>
nope. |
Re: (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 »</TD></TR><TR><TD CLASS="quote">i actually had several problems with my water pump when i had it inspected and replaced.</TD></TR></TABLE>
are you thinking my start up squeaking could have something to with the actual water pump itself? I was told my water pump was bad so I changed it out. But there wasn't anything wrong with it actually, so I took the old water pump and stored it in a container full of oil to keep everything good. So when the new pump went bad, I just replaced it with the old one after I cleaned it up. hmmmmm....what is going on under that hood? |
