damn car!!
damn car!!
ok..i finally got my d16z6 running in my 95civic coupe...and then i took off the damn distributer...and when i put it back on..it would not start. it just turns over and over...and i know i got my plugs in the right spot..i just dont know what is wrong with it. ne suggestions..thanx
Re: damn car!! (fastgreenmachine)
did you put the distributer on exactly how it was on before you took it off? your timing is more then likely off.
Re: damn car!! (careawholelot)
Re: damn car!! (purek9hybrid)
that might be it.cause i had two alternaters..and one of them came off a wrecked car.with same motor..but i dunno. ill just try the other one..and see if it works right. thanx for the advice.
Solbros Owns Me
Re: damn car!! (romeo619)
as long as you get it in, it should run. You're car will run within a range of 40 degrees of ignition timing. Have someone crank it with a timing light and see if you have spark
yo bj
02-02-2011 05:54 PM
