Daily 300whp on a d16z6
So I have so far:
-adjustable fuel pressure regulator
-450cc injectors
-aem 320 fuel pump
-y7 intake manifold
-62mm throttle
-42/48 turbine
I know I need better connecting rods and piston but my confussion is that some pleople say that I can run it without touching the block but do I need at least a blockguard?
-450cc injectors
-aem 320 fuel pump
-y7 intake manifold
-62mm throttle
-42/48 turbine
O.G. triple O.G.
Re: Daily 300whp on a d16z6
1. hope it's an Aeromotive instead of those shitty fuel rail mounted ones
2. DSM injectors??
3. get a Walbro 255lph
4. don't forget a new I/M gasket, Genuine Honda or Hondata
5. Stock TB is suffice
6. Hope it's not a cheap Chinese made eBay crap
You left out 2 important items....
upgraded aftermarket clutch and engine management
2. DSM injectors??
Y7 intake manifold? You probably want at least a y8 intake manifold. Yes upgrade the pistons and rods, but no need to sleeve at this level.
Stay away from block guards, they are trash, do it the right way and go CSS. Cylinder support system is rated/warrantied to 500whp....
Cylnder Support System ? Cyllnder Support System
EG-SIXV-TEC
05-29-2012 03:40 AM
jefe
05-09-2006 11:38 AM
mrehagencivic
29
12-14-2004 11:11 AM
