d16z6: what gear to dyno pull at? 3rd or 4th?
Unceasing Measure
Re: (skidder84)
Closest to a 1:1 ratio so you don't have to do math to determine proper power output. If you do it in a 2:1 gear or a 4:1 gear (just random numbers), the result will be off by 1/2 or 1/4 depending.
Unceasing Measure
Re: d16z6: what gear to dyno pull at? 3rd or 4th? (mike93eh)
You can always Google the gear ratios and do it yourself. It would take less time than posting on Honda-Tech.
Guest
Posts: n/a
Re: d16z6: what gear to dyno pull at? 3rd or 4th? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">You can always Google the gear ratios and do it yourself. It would take less time than posting on Honda-Tech.</TD></TR></TABLE>
and it would of took less time for you to just say 3rd or 4th..
Guest
Posts: n/a
ok, mister smarty pants...
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
btw, i wanted to know what other people have used when they went to the dyno, actual experiences, not some google search.
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
Final Drive---4.250
Guest
Posts: n/a
Re: (blueb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueb18c »</TD></TR><TR><TD CLASS="quote">if you go to the right place and the tech knows what hes doing he'll do it in 3rd and take it up the power band nice and easy. </TD></TR></TABLE>
you mean slowly give it gas in 3rd until its all the way floored?
Re: (x_outlaw_x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x »</TD></TR><TR><TD CLASS="quote">shouldnt the shop that you dyno it at know?</TD></TR></TABLE>
They should. There going to tell you 3rd as well. If you dont want to believe people here then just do it whatever gear you want.
Rocket
46
09-30-2010 10:42 PM
cruzersi99
18
08-24-2005 09:08 AM
