d16z6 stutter problem
Old 03-31-2010, 07:22 PM
Nfire247's Avatar
Default d16z6 stutter problem
So , i've got a 1997 dx civic w/ a d16z6 (yeah lol weird i know) running a stock harness w/ an obd1-obd2a jumper harness and a p28 ecu.
At idle, when i floor it, the car jumps to maybe 1500rpm, falls slightly for about 2 seconds then revs freely to redline. All of this under full throttle. Accelerating from 0 is challenging sometimes, usually after idle when i haven't revved it up first, the car stutters and jumps until i even out on the throttle, or it gets a hold of itself (usually 1-2secs) and accelerates normally. After any prolonged amount of constant throttle, the car stutters and pauses before accelerating when i push on the gas.
I've tried 2 ecu's, a chipped P06 and now a stock p28 and it does it with both.
Am i dealing with sticky injectors or something?
any ideas would be helpful.
Old 03-31-2010, 07:35 PM
95soul's Avatar
Default Re: d16z6 stutter problem
Perhaps it could be a fuel delivery problem. Have you changed your fuel filter?
Old 04-01-2010, 09:34 AM
Counterfeit169's Avatar
my car did same deal it was distributor, borrow one from someone and test it
Old 04-01-2010, 02:25 PM
wmac's Avatar
how did you connect your distributor?
z6 distributor has 2 plugs and obd2a engine harness have only one (for the distributor).
did you just do the swap?
Old 04-01-2010, 02:32 PM
Nfire247's Avatar
wired it using a z6 harness
hmm thats actually a good start though! we did swap out the dizzy for a used one a buddy had... it def. could be having problems.
is this still a possibility if its running fine up in higher rpms and at any constant throttle?
i'll check the fuel filter too, but its pretty new so i doubt it.
Myed9Rex
11-03-2014 06:44 AM
sweetbbyrays
03-21-2012 05:12 PM
boostfreak0885
01-22-2008 04:10 PM
SoHc94
11-02-2006 09:01 AM
Quick Reply: d16z6 stutter problem
