d16z6 rare or not
d16z6 rare or not
i just brought a 94 civic ex and when i open the hood it say vtec on it, but when i look at other 94 ex there no vtec on it. so is this any special or no? or it the same ****?
Re: d16z6 rare or not
know a turbo ek with Z6 block and y8 head. < has smaller combustion area, ups compression some. that ontop of some vitara build specs is very nice
H-T White Ops
The part about the years is correct. I made a thread about this a few years back and got lots of feedback.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/vtec-valve-cover-2204762/
95Sol99civic: no all the D16Y* Engines have the same oiling system. Its only 1 oiling port per bearing instead of the 2 on the rest of the D series motors.
I know my SI del Sol's trans is way different gearing than any EX or SI trans. It has alot of take off but the only thing is it gets alittle crappy gas mileage on the highway. If I stay between 55-60 then I get 40ish on the highway around 35 mpg.
H-T White Ops
The only different parts I found between the four were:
CLIP B, HARNESS BAND (DARK BROWN)
- 91507-P01-003
- del Sol Si
- (NOT ON CIVIC EX COUPE, CIVIC SI HATCH OR CIVIC EX SEDAN)
GEAR, MAINSHAFT FIFTH
- 23581-P20-A00
- del Sol Si
- 23581-P20-C00
- Civic EX coupe
- Civic Si hatch
- Civic EX sedan
- (NOT ON DEL SOL SI)
GEAR, COUNTERSHAFT FIFTH
- 23461-P20-A00
- del Sol Si
- 23461-P20-C00
- Civic EX coupe
- Civic Si hatch
- Civic EX sedan
So the only real performance difference between the transmissions would be the fifth gear.
Interestingly enough it also appears (at least) the '93-'95 del Sol S and Si share the same transmissions.
Are you sure you have the stock transmission? Perhaps you need a tune up.
I just checked FuelEconomy.gov and it says the 1995 del Sol Si with a manual transmission should get about 25 mpg city and 32 mpg highway.
H-T White Ops
This thread, contrary to what the thread title might lead you to believe, is NOT about how rare the D16Z6 is or is not. It's about a part on the D16Z6 and how common it might be. It's been answered already too.
I get around 40 mpg if i stay around 55-60mph and on highway speeds 70-80mph I get around 35mpg. Sorry I didn't make that clear. But I think that the big difference may be the final drive. I had an S model also and it was very pepy for a 1.5 so that kinda expains alot thanx for the info guys.
Jamesg_si
13
08-17-2016 11:13 AM
nomoreavril
03-15-2008 02:11 PM
