d16z6 no spark
Old 05-21-2013, 10:20 PM
89ED's Avatar
Default d16z6 no spark
5 speed. i can here the pump and injectors workin. im getting no in any of the 4 cylinders.
i read a thread and proceded to remove the distributor cap. i then unbolted the transmission ground from the chassis not the transmission. turned the motor over while holding the ground close to the distributor rotor and that little spring (what is that?) to see if a spark would jump but got nothing. while writting that last sentence i wondered if it would have been more wise to unbolt the ground from the transmission and not from the chassis to do the procedure. if suggested i will do it again. anyway what wires to the distributor should i check for power, continuity, ground ect
Old 05-22-2013, 01:17 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: d16z6 no spark
Checking for spark
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-how-test-spark-troubleshoot-spark-problems-2919450/
Coil test
Ignitor test
Old 05-22-2013, 10:28 AM
89ED's Avatar
pretty good info but it looks like those are two different distributors and wheres the rotor on either of them do i have to remove the rotor to get the that stuff. if so how do i take it off
Old 05-22-2013, 11:00 AM
Former User's Avatar
You need to remove the rotor screw.
To make the screw accessible, remove the 15A hood ECU fuse and then flick the ignition key to ON(III)/START until the screw is visible.
hyabusa hunter
21
10-19-2010 01:38 PM
tundra2000
06-08-2010 03:27 PM
CptCorN
01-17-2005 06:33 AM
KaRiZMa
11-07-2004 03:30 AM
chewiejdh
02-29-2004 09:47 AM
Quick Reply: d16z6 no spark
